Lifted, aligned, noisy front end - JeepForum.com
post #1 of 6 Old 05-05-2012, 01:34 PM Thread Starter
Destrobot
Just lifted my liberty, 1.5" OME lift from JBA. I also installed JBA upper A arms. I got it aligned right after at town fair tire. They did a factory alignment and told me they couldn't get the front right tire at 0 degrees. Normal for a ****ty tire shop looking to make money. So now when I drive on any road, not big bumps, I hear a semi clinking noise on the front passenger side. not to loud or harsh sounding but it's there. I didn't hear this for the 4 miles I drove before the alignment. I know it could be the strut nut on top, the sway bar, or just a bad alignment. Any ideas? I torqued everything to specs and checked twice.
Here's a picture of the alignment print I got
I also installed teraflex bump stops and hockey puck back bump stops. Any ideas on what this rattling/ clunky sound is I would love to know
07 JK - 6 Speed - 33" Duratracs Full Skids 17/59 coils with Rubicon shocks License Plate relocation
Destrobot is offline
post #2 of 6 Old 05-05-2012, 01:44 PM
SabaII
Well not sure on the noise. It is most likely something left loose. Another issue you may have is the caster. The difference is .3 degrees. If I remember right if caster is .3 degrees or more different it will pull to the most positive side. (Someone correct me if I am wrong) You may not notice it since it is so small but if I was doing that alignment if I couldn't get it within spec I would try to at least get rid of the difference.
SabaII is offline
post #3 of 6 Old 05-05-2012, 07:17 PM
streetglideok
2005 KJ Liberty
Cars pull to the most camber, or least caster. Some vehicles will exhibit camber pull with anything more then a 1/4 degree difference on camber, and a half degree difference on caster. The camber is on the line on the left side for factory spec tolerance, the right side is barely beyond. If you put some conduit spacers on the front, I imagine the camber may drop some and be in spec more . Caster is lower then I like to see on a 4wd with power steering. The 0.3 degree difference isnt a big deal, I would be happy with that if that got the camber close to equal. Someone with experience on the lift kits and aligning afterwards can tell you more on how close things should be. As for clanking noises, double check everything, to make sure its tight. Double check the lower control arm bolts, as they were loosened to adjust camber/caster.
streetglideok is offline
post #4 of 6 Old 05-05-2012, 07:41 PM
tjkj2002
2002 KJ Liberty
Attachment 392361
Go back and have them center the camber and get caster in or around 2-2.5 degrees with no more then 0.5 degrees cross caster and you will be good for that.You will need another alignment in about 6 months anyways due to settling,and again at least once a year which is always a good idea anyways on any vehicle.
As far as the "noisy" front end check those swaybar end links,they need to be upper tight or they make noise.Also not fully tightening the upper coilover assmbly nut is also another major noise for fresh lifted KJ's.
tjkj2002 is offline
post #5 of 6 Old 05-05-2012, 08:24 PM Thread Starter
Destrobot
Ahh alright gonna have another alignment. Im guessing I'm going to have to pull the whole assembly out again to tighten that what ever makes the sound leave is gonna have to happen
post #6 of 6 Old 05-12-2012, 05:31 PM Thread Starter
Destrobot
Okay so I re torqued everything except strut top nut. I replaced the sway bar links with moog links. I'm still hearing a tiny bit of play in the front passenger side. What's the best way to get the strut out, unbolt the clevis or take out clevis fork? It's kinda a PITA to get the strut in the clevis, so I'm looking for ways around that
