Liberty towing - JeepForum.com
post #1 of 17 Old 07-18-2013, 08:12 PM Thread Starter
Rayford
Liberty towing
I need to tow a 2001 Jeep Wrangler 1700 miles. I have a 2006 3.7 auto. gas no towing package. It does have an after market hitch 5000 lb. max.
Can i do this with a car doly.
Rayford is offline
post #2 of 17 Old 07-19-2013, 06:46 AM
TwoBobsKJ
2003 KJ Liberty
Yes, you can pull the Wrangler. Turn off overdrive on any hills to keep the tranny from getting too hot.
Most importantly, beware of space between you and vehicles ahead of you. Biggest challenge with towing is stopping the rig, not getting it moving. Not that the Libby's brakes are bad but without trailer brakes you're relying on the tow vehicle to do all the braking by itself.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #3 of 17 Old 07-19-2013, 09:49 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Here's info from the 2006 KJ Owner Manual:
Trailer Towing Weights (Maximum Trailer Weight Ratings)
The following information provides the maximum trailer
weight ratings towable for the given drivetrain.
3.7L/Automatic 4x2
GVWR (Gross Vehicle Wt. Rating) 5,350 lbs
GCWR (Gross Combined Wt. Rating), 7,150 lbs
Frontal Area 32 Sq. Ft.
Max. GTW (Gross Trailer Wt.) 2,000 lbs
Max. Tongue Wt. 200 lbs
3.7L/Automatic 4x4
GVWR (Gross Vehicle Wt. Rating) 5,600 lbs
GCWR (Gross Combined Wt. Rating) 7,400 lbs
3.7L/Automatic with cooler 4x2
GCWR (Gross Combined Wt. Rating), 9,850 lbs
Frontal Area 60 Sq. Ft.
Max. GTW (Gross Trailer Wt.) 5,000 lbs
Max. Tongue Wt. 500 lbs
3.7L/Automatic with cooler 4x4
GCWR (Gross Combined Wt. Rating) 10,100 lbs
JeepCares is online now
post #4 of 17 Old 07-22-2013, 01:27 PM
Ted15
2010 KK Liberty
Don't use a toe dolly, you'll mess up your wrangler's drive trail.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #5 of 17 Old 07-22-2013, 02:48 PM
02libbyfirstcar
2002 KJ Liberty
can i add a trans cooler if mine doesnt have one so i can tow more?
02libbyfirstcar is offline
post #6 of 17 Old 07-23-2013, 09:52 AM
TwoBobsKJ
2003 KJ Liberty
You almost certainly have one already - most Liberty's do.
Look in front of the radiator along the bottom. You'll see a cooler running horizontally about 4 inches tall with lines that come from in the right side of the engine and through to the front of the grill. Look for the metal and rubber lines noted with the yellow arrows in this pic on the right/passenger side of your engine bay. They are the transmission cooler lines running from the tranny to the cooler in front of the grill. Ignore the other hoses - they're for a mod I did:
Bob
post #7 of 17 Old 07-23-2013, 08:49 PM
Bain98xj
As long as the wrangler transfercase is in neutral amd the trans is in park you will not mess up the drivetrain
Bain98xj is offline
post #8 of 17 Old 07-24-2013, 04:52 AM
Ted15
2010 KK Liberty
I'd agree with you 100% but my owners manual said not to. It also said to use a flatbed tow truck. Just sayin, I wouldn't risk it.
Ted15 is offline
post #9 of 17 Old 07-30-2013, 06:31 AM
codyjames
When I tow my tj on a car dolly I just pull the rear drive shaft, It's 4 bolts. I have towed it short distances with the tc in neutral but for such a long trip I'd just pull the DS just my opinion though
ocean state jeepsters
codyjames is offline
post #10 of 17 Old 08-01-2013, 11:16 PM
ech0sh4y
2008 WK
I'd assume that you lose your fluid if you pull the shaft unless it has a sye
~ Brian
2008 WK Overland CRD
ech0sh4y is offline
post #11 of 17 Old 08-03-2013, 08:25 PM
Lendo
Can you beef up the suspension with an OME kit to pull a larger trailer?
Lendo is offline
post #12 of 17 Old 08-03-2013, 08:33 PM
Lendo
Maybe with something like this?
http://www.quadratec.com/products/76090_50X_PG.htm
Lendo is offline
post #13 of 17 Old 08-04-2013, 06:00 AM
Ted15
2010 KK Liberty
That'll help to hold the weight but you'll still have to be able to pull and stop. I use a load leveling hitch, a very small one made by Reese. It distributes the weight and has sway control built into it. I still don't go over the recommended weight though, the camper is around 2000 lbs empty.
Ted15 is offline
post #14 of 17 Old 08-04-2013, 08:47 AM
John317
I have a friend that flat tows his xj to Florida and back behind his motorhome with the transfer case in neutral and transmission in park with no issues. But obviously he doesn't have problems with braking with the extra weight. I pulled hi xj this summer with his pickup and it shoved his 3/4 ton around a little. And if you do this watch your turns and cornering, its a little different than a trailer or tow dolly.
John317 is offline
post #15 of 17 Old 08-04-2013, 05:56 PM
Lendo
This is what I'm thinking of going with. http://www.trailmanor.com/WebDocs/fo...line/3124.html
Lendo is offline
