Liberty Sport won't start engine- consider alarm system malfunction - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Liberty Sport won't start engine- consider alarm system malfunction
The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 08-01-2008, 02:51 AM   #1
WojBear
I have Jeep Liberty Sport Diesel 2003 with 120 000 miles. It was working perfectly up until yesterday, I turn it off at the gas station and when i got back it didn't start up again. I considered driving it to dealer but the next morning it started again like nothing happened. when i turned it off and put alarm on, the problem started again but this time it won't start. I noticed that engine is working but it just doesn't receive any fuel. i think it maybe is alarm system not working correctly but i'm not sure. i heard something about EGR, what do you think? is there a way to fix it myself?
WojBear is offline   Reply With Quote Quick reply to this message
Unread 08-01-2008, 06:43 AM   #2
merlinTec
Hi
When it doesn't start can you try turning the key on off 3 times but not start it see if you get any codes come up in the display. will the engine turn over? if so it's not the alarm.
UK Chrysler Jeep Master Tec.
merlinTec is offline   Reply With Quote Quick reply to this message
Unread 08-01-2008, 11:21 AM   #3
WojBear
i checked and it looks like it is a alarm system. any idea how to fix a problem or maybe reset alarm system? a way to disable alarm completly would be helpfull too
Unread 08-01-2008, 01:05 PM   #4
johnstranko
I would imagine there would be a fuse for that that you could just pull out and disengage power to it, however I am a toyota person, so I dont know what kind of implications would arise buy defusing it. I believe the fuse for that is in the box in the engine bay by the battery. If defusing it causes any weird **** to happen, just stick the fuse back in.
johnstranko is offline   Reply With Quote Quick reply to this message
Unread 08-01-2008, 01:08 PM   #5
merlinTec
Hi
Do you have the SKIM light on the dash? this will tell you the immobiliser is on. The alarm is only the alarm It's the SKIM around the key barrel and the key that is the immobiliser and I can't tell you how to get around it. Reset would be to just disconnect and reconnect the battery.
Regards,
Merlin
Unread 08-01-2008, 01:58 PM   #6
WojBear
i'll try this and then post a reply, but just in case, do you think this is a real problem or something else? thank you for your help by now
Unread 08-01-2008, 02:10 PM   #7
WojBear
it's not the immobiliser. well just in case, the problem is actually fuel not going to engine, because i can see engine working but it won't ignite. i thought it maybe is power lock malfunctioning, what do you think
Unread 08-01-2008, 02:41 PM   #8
WojBear
i completly forgot to mention that car started few times today but when i turn it off it didn't start again.
Unread 08-01-2008, 02:45 PM   #9
merlinTec
Hi
When it doesn't start if you pump prime pump on the fuel pump on the filter housing will it then start?
