Liberty Rattling Noise when AC on - JeepForum.com
post #1 of 13 Old 08-10-2013, 01:13 PM Thread Starter
sebastien7
I have a 2003 Jeep Liberty Sport. When I turn on the AC there is a loud rattling sound coming from near the tension pulley/compressor area as best I can tell. I've the whole tension pulley assembly and put a new belt on it about a month ago so I don't think it could be that. It goes away when I turn the AC off or accelerate. I read somewhere it might be the ac compressor clutch but want to make sure before I start replacing items - any ideas?
Thanks.
sebastien7 is offline
post #2 of 13 Old 08-10-2013, 02:25 PM
PeteH
What did you do to the pulley assembly. Your post is missing a word or two. It was the tensioner assembly, not the pulley bearings on our 03. I bought the entire assembly with both pulleys from NAPA for @ 50 or 60 bucks. Only made noise when the A/C compressor first came on in the morning or after a cool down.
PeteH is offline
post #3 of 13 Old 08-10-2013, 02:46 PM Thread Starter
sebastien7
sorry I meant I replaced the whole assembly
post #4 of 13 Old 08-10-2013, 03:19 PM
PeteH
Buy a cheap mechanic's stethoscope and pinpoint the noise. Hopefully cheap and easy.
PeteH is offline
post #5 of 13 Old 08-10-2013, 06:27 PM
John317
Bad Tensioner, some manufacturers products are known not to last to long.
John317 is offline
post #6 of 13 Old 08-10-2013, 06:28 PM
tjkj2002
2002 KJ Liberty
Yep it's bad tensioner.
tjkj2002 is offline
post #7 of 13 Old 08-11-2013, 12:58 PM Thread Starter
sebastien7
Everyone thinks its a defective tensioner? I changed the whole assembly about a month ago. I guess I could swap it out for a new one again and see if that works. If it doesn't I guess I can just return it.
post #8 of 13 Old 08-11-2013, 12:59 PM Thread Starter
sebastien7
Again, it doesn't make any noise until the AC is on.
post #9 of 13 Old 08-12-2013, 04:35 AM
PeteH
Bad tensioner makes a snapping/ rattling noise. Like a loud clicking/knocking that is not consistent. It really does not increase in frequency when you up the rpm's a tiny bit. It does go away when you accelerate.You will see the timing belt/tensioner jump around a little.
The A/C compressor makes a steady rattling noise that increases in frequency when you increase rpm slightly. It may or may not go away with acceleration.
The tensioner is cheaper than the compressor.
PeteH is offline
post #10 of 13 Old 08-12-2013, 06:05 AM
streetglideok
2005 KJ Liberty
Just because you replaced something a month ago, does not mean it's of decent quality, or could be defective. A lot of times the tensioner will rattle, and you'll see the pulley jumping, when you put a heavy load on the belt system, like the compressor. Also verify you have no wobbling pulleys too. Seen too many people try to pry off their power steering pulleys over the years. I once bought an advance auto parts tensioner for a car I used to have, it was all I could get and I was in a real bind. Rattled from the time I put the thing on, till it spilled its guts.
streetglideok is offline
post #11 of 13 Old 08-13-2013, 10:00 AM Thread Starter
sebastien7
Thanks everyone for the insight - greatly appreciate it. I will replace the tensioner again and hopefully it works. The last one I bought was off a vendor on ebay. Does anyone recommend a vendor or brand of higher quality?
post #12 of 13 Old 08-13-2013, 10:33 AM
John317
I would suggest you google it and draw your own conclusions. Not being a smarty but dont have long term results to post a reliable result. There are however numerous posts on this. That being said I went with a Gates from NAPA. The autozone Dayco did not have a good review. And they were only $4 dif in price.
John317 is offline
post #13 of 13 Old 08-13-2013, 12:09 PM
tjkj2002
2002 KJ Liberty
No wonder why it failed so soon.
Goodyear tensioner and Gates tensioners are good,nothing really wrong with a dayco tensioner as it's 100 times better then the OEM one and those no named versions.
tjkj2002 is offline
