Liberty with no speedo or cruise???? - JeepForum.com
post #1 of 8 Old 09-11-2010, 05:06 PM Thread Starter
JeepLDon
2003 KJ Liberty
Hello, I have a 2003 Liberty Sport 4x4 and the cruise does not work properly as does the speedo. The speedo bounces around until the brake is applied a few times then steadies out, at the wrong speed reading. The cruise is probably not working because of this erratic behaviour.
The Mopar dealer has gone through the wiring, supposedly and the problem was fixed for about 2 days then went right back to being erratic. I am thinking that the brake light switch might be at fault or the electrics to the cruise from the ECM or PCM. Everything else works fine and the car drives and shifts perfectly, so I am not suspecting the speed sensors.
Any suggestions? The wire pinched at the brake line is not an issue here.
JeepLDon is offline
post #2 of 8 Old 09-12-2010, 12:41 PM
richd
2008 KK Liberty
I would say you still have a wiring problem,or a bad speed sensor.If it worked after repair then stoped,then recheck what they did.
richd is offline
post #3 of 8 Old 09-12-2010, 07:14 PM Thread Starter
JeepLDon
2003 KJ Liberty
Just tonight on the drive home the check engine MIL came on, so tomorrow I will check and see what code may be set this time. Last time it was a generic P0500, indicating a malfunction with a speed sensor w/manual trans!?
I have an auto w/od and manual transfer case.
JeepLDon is offline
post #4 of 8 Old 09-13-2010, 08:31 AM
sweepnchoke
2002 KJ Liberty
Had the same issues on my wife's, and it was bad connection to the rear speed sensor. Cable was chaffed right at the plug for the speed sensor. Trimmed and resoldered the connection, speedo and cruise working with no issues.
http://www.cardomain.com/ride/2434197
sweepnchoke is offline
post #5 of 8 Old 02-24-2011, 01:29 PM
AndyTee
2002 KJ Liberty
Can you describe where about the rear sensor is located please :-)
Thanks
Andy
AndyTee is offline
post #6 of 8 Old 02-24-2011, 07:14 PM
troyford417
2002 KJ Liberty
hey Andy, the speed sensor is located on top of the rear differential/axle. Mine went out and gave the same problems your having. Dealer part and was expensive but problem solved...
troyford417 is offline
post #7 of 8 Old 02-25-2011, 12:11 AM
AndyTee
2002 KJ Liberty
MAny thanks. I'll get that checked (I'm offshore at the moment and will have to relay this info back home). The caris cutting out when you approach a junction or roundabout and the code P0500 is coming up on the console.
Thanks again
andy
AndyTee is offline
post #8 of 8 Old 02-28-2011, 08:22 PM
Tkarner03
2002 KJ Liberty
Question?! im having the same problem but when i put it in nuetral (5 speed), it dies. after restart it runs and idles fine until clutch in engaged again. is this all related?
Tkarner03 is offline
cruise control , liberty , speedometer , sport
Adding cruise control to 2007 Liberty??? uscgman KJ Liberty Forum 3 08-19-2013 03:35 PM
Cruise control on my 2002 Jeep Liberty is going haywire...? mvparker79 KJ Liberty Forum 2 12-10-2009 12:55 PM
Liberty Cruise Intermittent dabincharlotte KJ Liberty Forum 3 01-23-2008 02:09 PM
Liberty Cruise control photobar KJ Liberty Forum 5 10-29-2003 01:37 PM
