liberty fender flare - Page 2 - JeepForum.com
post #16 of 17 Old 05-21-2013, 11:29 AM
tommudd
2004 KJ Liberty
Originally Posted by FrenchChristian View Post
To run 35s he went to a soild front axle and of course more lift
To run 33s you'll need to regear to 4.56s / have 6 inches of lift and a steel front diff from JeepinByAl
Hi Tommud,
I have at the moment a Full OME all round with 12 mm plates between the body and the top of the front struts and a 10mm thick washer at the Clevis. I am going to replace the new generation of rear OME struts by the OME N132L Long Travel so I can add 2 Rubber Isolators each side of the rear Springs and hopefuly lift the rear again. How far do you think I could go in the Front by adding thick washers between the Clevis and the bottom of the strut but to keep everything in good working order ? I am really wondering if I could reach a 6 in lift that way?
No way to get 6 inches that way, you'll have issues with the spring hitting the UCAs at around 4 inches, so if you went to 6 it would be undriveable.
Most you can add and still be driveable is 3/8 inch clevis and 1/4 inch top plate . To go 6 inches you'll need to move up to one of JeepinByAls 6 inch kits
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #17 of 17 Old 05-22-2013, 04:53 PM
FrenchChristian
2006 KJ Liberty
Thanks Tommud,
I am going to investigate the possibility of having made to measure fenders and stick with 31in tyres for now. I am thinking of adding wheel spacers to compensate the higher center of gravity. Have you ever heard of anyone who tried and experienced problems with those?
FrenchChristian is offline
Fender flare! bikinman1226 KJ Liberty Forum 1 03-04-2010 02:16 PM
Right fender flare missing bikinman1226 KJ Liberty Forum 4 11-29-2009 10:48 PM
Fender Flare soccerstar1 KJ Liberty Forum 4 10-04-2009 12:23 PM
Fender Flare on 2002 Jeep Liberty errinm02 KJ Liberty Forum 0 07-24-2009 02:11 PM
liberty fender flare question Derek33 KJ Liberty Forum 4 10-01-2007 08:51 AM
