Liberty CRD Diesel Glow Plug Part Number - Page 2 - JeepForum.com
post #16 of 28 Old 08-27-2011, 02:49 PM Thread Starter
dabincharlotte
2006 KJ Liberty
My glow plug light is at about the 10 o'clock position from the speedometer. In your picture, it is just to the upper left of the seatbelt light.
dabincharlotte is offline
post #17 of 28 Old 08-27-2011, 04:59 PM
flman
2006 KJ Liberty
He has a special one of a kind CRD with no glow plugs, no electronics to run them and no CEL that would happen on every other CRD that did not have glow plugs.
Still Burnin Oil since 1992!
GDE ECO Tuned 2006 CRD Sport Black, B&G Trans drain kit, Front and rear hooks, Full Skids
GDE HOT Tuned 2006 CRD LTD Silver, B&G Trans drain kit GDE TCM tune
2010 MB 2500 Sprinter Van
2005 MB 2500 Sprinter Van
flman is offline
post #18 of 28 Old 08-27-2011, 05:04 PM
JeepinJarhead03
so...
He's got a 4bt :P
Correction:
6bt
double :P
JeepinJarhead03 is offline
post #19 of 28 Old 08-27-2011, 06:42 PM
CodyJ5
2005 KJ Liberty
I dont know what i have. The guy before me could have taken them out, the light itself could be out. I dont have much of a clue.
CodyJ5 is offline
post #20 of 28 Old 03-16-2012, 09:08 AM
Longschott
your glow plug indicator.
Originally Posted by CodyJ5 View Post
I dont have that indicator. Heres what my dash looks like when i put the key to run.
www.jeepforum.com/gallery/data/12/0827011115.jpg
You have the '06 on your dash it is the little red light. Looks like a little red dot. It is at the 7 o'clock to the tac.
Longschott is offline
post #21 of 28 Old 03-17-2012, 07:40 AM
CodyJ5
2005 KJ Liberty
So thats the glow plug indicator or what?
CodyJ5 is offline
post #22 of 28 Old 03-18-2012, 07:49 AM
mikey1273
2006 KJ Liberty
No I have an 06 also and the glow plug light is not the red LED.... that is light is for the security/key century system. The glow plug indicator is an orange curly thing like pictured but on the liberty it is in the upper left near the seat belt light. I still think you may be missing it the light is only one a few seconds after the key is turned to run. It is possible your indicator light is burned out too.
the underhood parts have still got to be there
mikey1273 is offline
post #23 of 28 Old 02-21-2014, 04:57 PM
lanthony2020
EPA requires them. If the motor is warm enough, my light wont' come on. Sometimes just for a second.
Like my F350 7.3, I wonder if the plugs stay on longer than the light does? Does anyone know this?
You for sure have them.
lanthony2020 is offline
post #24 of 28 Old 02-21-2014, 05:57 PM
02jeepliberty
You can check to see if that light goes on by holding the trip button and turn key to the ACC position. Every light should go on on the speedo, even if it isn't equipped with something (ex.security system, fog lights) and the needles will all move. Give that a try and see if you see the curly line
02jeepliberty is offline
post #25 of 28 Old 02-21-2014, 06:41 PM
lanthony2020
Thanks for the tip!
LN
post #26 of 28 Old 02-22-2014, 01:21 AM
Billwill
2002 KJ Liberty
The glow plugs definitely stay on a lot longer than the lamp shows.
There is a lot of discussion on lostjeeps at the moment regarding glow plugs and cold starting problems.
Basically the consensus...and it is in the Service Manuals...is that depending on ambient temperature the glow plugs stay on for a few seconds and then are pulsed at about 1/4 duration for up to 200 seconds.
It is also the consensus that in very cold conditions it is worth turning the ignition ON for a few seconds...turn OFF then ON again for a few seconds and repeat a few times....this gets the glow plugs really warm for a good start.
This does not concern me..I live in a warm climate and could disconnect my glow plugs and would get good starting with just a puff of smoke!
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #27 of 28 Old 02-24-2014, 12:08 PM
lanthony2020
What temp do folks start having start problems with these, before the start plugging them in? Also, I wonder if 0w-30 or 5W-30/40 makes a difference. My F350 7.3 will start at 20 below with 10W-30 but I have to cycle 2 or 3 times with 15W-40, even synthetic?
LN
post #28 of 28 Old 02-24-2014, 05:21 PM
95BadBoy
LN
Depending on how long you leave it parked I guess. When you start seeing 15 degree numbers - good idea to plug it in & double cycle the glow plugs when you fire things up. You really don't need to run zero degree euro oil. 5-40 should do the job just fine.
If you are dealing with the -20 -30F I see here at times, a battery warmer is also not a bad idea to have - along with the block heater.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
CRD Glow Plug Failure andyc979 KJ Liberty Forum 8 06-07-2013 06:58 AM
Shock/Spring Part Number for 2005 Liberty? MachSilver08 KJ Liberty Forum 1 08-07-2011 06:09 PM
02 Liberty Bumper/Flare clip part number? d5332 KJ Liberty Forum 4 01-26-2011 11:03 AM
CRD, Where is Glow Plug Relay Blindminer KJ Liberty Forum 1 12-12-2006 07:47 PM
Glow Plug Light? Drewd KJ Liberty Forum 11 02-13-2006 11:26 AM
