KJ Lift Quick Question - JeepForum.com
post #1 of 7 Old 07-19-2013, 12:09 AM Thread Starter
tedo2007
2003 KJ Liberty
Going to order the Frankenlift II Premium Kit for GAS KJ tomorrow.
Is there anything else I need to order online to get max lift with this kit? Spacers, etc?
Clevis?
Wanting to fit 31x10.5x15 tires.
I did some research, just wanting to check before ordering as to be sure I dont forget anything.
Thank you!
tedo2007 is offline
post #2 of 7 Old 07-19-2013, 06:32 AM
tommudd
2004 KJ Liberty
Nothing else
Can't add clevis etc as it would be too much lift
with those tires you'll lose quite a bit of power so may want to think of regearing in the near future
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
05 KJ
tommudd is offline
post #3 of 7 Old 07-19-2013, 03:39 PM
Luke09
2005 KJ Liberty
^^^ definitely ... it will be a long while before you can stuff anything else in the front!
2005 Liberty Renegade - Dark Khaki
Frankenlift IIP, Mobil1 Synth.& Filter, PIAA Extreme White, Amsoil EA Filter, Spidertrax 1.25, 245/75/16 Duratracs
Luke09 is offline
post #4 of 7 Old 07-19-2013, 04:16 PM Thread Starter
tedo2007
2003 KJ Liberty
Ill be running the arb front bumper as well ordering that tonight, do i need to order different shocks / struts?
Can ya point me to gears?
tedo2007 is offline
post #5 of 7 Old 07-19-2013, 04:23 PM
tommudd
2004 KJ Liberty
All front shocks are the same no difference at all
Front springs if going with Frankenlift then just what you have
If building your own then you can go with OME 790s up front , they are the ones for the CRD and will handle the weight of the aftermarket bumper and winch
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
post #6 of 7 Old 07-22-2013, 09:43 PM Thread Starter
tedo2007
2003 KJ Liberty
Alright, so the frankenlift reuses old struts / springs? I was explained it was new parts!
Blah, im so confused.
Someone had suggested if putting an ARB on the front to go with the frankenlift 2 for crd, rather than gas for added support up front.
Thanks for the help
tedo2007 is offline
post #7 of 7 Old 07-22-2013, 10:15 PM
tommudd
2004 KJ Liberty
No Frankenlifts uses all new springs/ shocks etc
If you were to use the CRD Frankenlift it would hold more weight BUT would not give you as much lift since you can't lift a CRD as high as gassers
Some of us have built our own "Frankenlifts" using CRD OME790 springs and gasser Franky parts
So Frankys for gassers use 927 springs rated at 400 lb and will hold up a ARB, did mine for 100,000 miles
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
