Quantcast Kj Faq - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Kj Faq
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 11-28-2004, 11:12 PM   #1
TJchick
Kj Faq
Hey all! I'm working on creating a KJ faq. Would you guys mind checking over my info and giving me some feedback. Also, you all are welcome to use this info if you find it useful.
Thanks!
Oh, I don't have a KJ, but I do have one in the extended family.
IFS=Independent Front Suspension
SAS= Solid Axle Swap
LOST Tech Info = http://www.kjjeep.com/custom2.html
Rock Crawler Review: http://www.rockcrawler.com/reviews/jeep/liberty_2002/index.asp
Specs: http://www.southpointjeep.com/liberty/specs/feature6.html
In April '02 the KJ springs were lowered 3/4".
Engines:
2.4L I4
2.8L I4 Turbo CRD (Common Rail Diesel) available in '05
3.7L V6 (pictured below)
Source: http://www.rockcrawler.com
Transmissions:
NV1500, 5spd comes with the 2.4L
NV3550, 5spd comes with the 3.7L Sport model
45RFE, 4 spd auto 3.7L in '02
42RLE, 4spd (same as '03+ TJs) in '03
NSG 370, 6spd available in 2005
Tcase:
NV231 Command Trac/Part-time
NV242 Selec Trac/Full-time
Front Axle:
D30, IFS
Rear Axle:
Chrysler 8.25, 29 spline
Lockers Available for the 8.25: ARB (selectable), Detriot, and Powertrax No Slip
Limited Slip Options for the 8.25: Auburn Gear LSD, Trac-Lok LSD
Available Gear Ratios:
3.55
3.73
4.10
*Optional 4 wheel disc brakes for all models
KJ Lifts:
Rusty's 2.5" coil spacer lift, or 2.5" suspension lift http://rustysoffroad.com/
OME suspension lift 1.5" front, 1.75" rear
Day Star 2" spacer kit
RockFather 2.5" spacer kit
Rocky Road Outfitters (RRO) 2.125" spacer combo and 2.5" OTT system
Good lift info.... http://www.rocky-road.com/kjsus.html
Tire Size Chart: (How much lift for X" tire?)
http://b22.ezboard.com/fkjjeepfrm16.showMessage?topicID=2.topic Sorry, this link is dead
Our DD/Trail Toy:
'04 TJ X, Khaki w/ Khaki Hard Top
4.0L, 5spd (NV3550), 231
D30/35, 3.73s, 2"BB, 31" BFG ATKO
Husband's Trail Rig:
'97 XJ, 2 DR SE, Dark Green
4.0L, 5spd (AX15), 231
6", 33" MTRs, D30 (truetrac), C8.25 (No Slip), 4.10s
www.JeepOnly.com
TJchick is offline   Reply With Quote
Old 11-29-2004, 07:07 AM   #2
PA_KJ
Here's what I would like to see in an KJ FAQ sticky thread. These questions are asked about once every other week.
What is the difference between lowered and prelowered?
What lifts are available for the KJ?
What is the largest tire size that will fit without rubbing (with and without a lift)?
What changes have occurred between the 2002 and (present year model) KJs?
L.O.S.T. #000102
'02 Shale Green KJ Sport 4x4 [URL=http://www.cardomain.com/id/zskys]My Jeep[/URL]
Rusty's 2.5" Coil Spring Lift, ARB BullBar, Goodyear MT/Rs, Skid Row and Mopar skids, Hidden Hitch/WARN Shackle, Sylvania Silverstars, Hella 500 foggies, Cobra 18WXST II CB (awaiting install), Firestick antenna (on order), Black Armor mats, L.O.S.T. sticker, and a bunch of factory options
PA_KJ is offline   Reply With Quote
Old 11-29-2004, 04:36 PM   #3
TJchick
OK, great! I know that the KJs were lowered 3/4" in April '02, which is the lowered/prelowered designation and makes some difference in tire fitting/lift results. I'll stick that in there along with some lift info and tire charts.
I have no idea on all of the changes for the KJs from '02 - '05. I'm still learning about all the TJ changes and working on that FAQ as well.
Thanks for the help!
Oh, I also tossed in some traction device info as well.
Our DD/Trail Toy:
www.JeepOnly.com
Old 11-30-2004, 03:00 PM   #4
LibertyV6
another thing is most people dont know when to use 4WD, or 4lo for that matter. (which weather/environment conditions must be present)
[FONT=arial narrow]2004 Liberty 4x4. [B]All Black[/B] Columbia Edition
Sunroof, 5 spoke Graphite wheels
[U]ADDED[/U] MAGNAFLOW stainless muffler, Turbolator exhaust tip, K&N drop-in, ECLIPSE CD5000 8V HeadUnit, Infinity KAPPA speakers (all w/ Dynamat) run off RF 800a4 amp, One 12" [COLOR=DarkRed][B]KICKER[/B] [/COLOR] [COLOR=Blue]Solo-Baric[/COLOR] L7 subwoofer - run off RF 500a2 amp, 2 AURA under-seat bass shakers using alpine Flex2 amp, Front/ rear Mopar window flares, front slush mats, eurostyle antenna, Power Horn with Uniden PA Mic, 3" Smittybilt step rails[/FONT]
LibertyV6 is offline   Reply With Quote
Old 11-30-2004, 03:33 PM   #5
PA_KJ
Your missing the following available lift kits:
All J Products Frakenlift 2.5" lift kit: http://www.boulderbars.com You have to ask for it. It's not listed on the web site.
BDS Suspensions - 2" front/1.5" rear lift kit: http://www.bds-suspension.com
Revtek spacer 2" lift kit: http://www.revtek.com
Skyjacker Platinum Coil Over 2.5" lift kit (LIB250K): http://www.skyjacker.com
Skyjacker spacer 2.5" lift kit (KJ25): http://www.skyjacker.com
Teraflex spacer 2" lift kit
Additionally, a couple companies are developing large lift kits:
RockKrawler 7-up long arm lift kit: http://www.rockkrawler.com/ A picture of a 7-up equipped KJ is currently on the front page.
Superlift 4.5" lift kit: http://www.superlift.com This lift is not listed on their site either. It is probably still in development.
L.O.S.T. #000102
Old 11-30-2004, 03:40 PM   #6
PA_KJ
Some more detailed information on the difference between lowered and prelowered...
All KJs produced prior to April 2002 are considered "prelowered". All KJs produced from April 2002 on are considered "lowered". Autoweek magazine rolled a 2WD KJ in a slalom test so fearing the potential fallout DC started lowering all KJs 22mm (0.87") in the front and 19mm (0.75") in the rear. There were several different front suspension set ups used throughout the earlier years so there may be several different heights for 2002s and 2003s.
Some information on model changes...
http://www.jeepforum.com/forum/f28/2003-vs-2002-kj-99580/?highlight=lowered
L.O.S.T. #000102
Old 12-02-2004, 07:44 PM   #7
LibertyV6
Which model year KJ rolled over in their test?
Old 12-03-2004, 07:03 AM   #8
PA_KJ
It was a 2WD 2002 Sport. Consumer Reports tested a 4WD 2002 and gave it a "thumbs up".
For more information--Jeep Liberty Rolls Over in Test
Old 12-03-2004, 02:55 PM   #9
LibertyV6
I'll read that link when I get back from work tonight.... Did the 4WD one pass because it was a heavier vehicle than the 2WD---- or because the driver engaged 4-HI in the 2nd test?
Old 12-04-2004, 11:16 PM   #10
Meister
it is probly a little late for me to be asking this, but how did the 05 2wd do in roll over tests?
2005 Liberty Renagade 2WD
Meister is offline   Reply With Quote
Old 02-07-2005, 09:04 AM   #11
Slipslap
Heres a site I found for KJ parts. They have plenty of other Off-Road parts, but they have a nice list of KJ stuff. And their products seem ok from I gather. Well here it is Rock Road Outfitters Not sure if it's been mentioned before. If anyone knows anything bad about them let it out.
Slipslap is offline   Reply With Quote
Old 02-15-2005, 11:30 AM   #12
Gsan
I don't think anybody mentioned the tranny change. something like a 45 tranny and a 42 tranny. I don't know all the details.
Gsan is offline   Reply With Quote
Old 05-06-2005, 06:17 PM   #13
TJchick
The '02 had the 45RFE and was switched to a 42rLe (same as '03+ TJs) in '03 based on this link.
http://www.storesonline.com/site/573683/page/372742
I guess I should probably add that to the top, huh...
Our DD/Trail Toy:
www.JeepOnly.com
Old 05-24-2005, 12:50 PM   #14
Valkraider
Additions to the FAQ
Also worth adding, is that the 2005 CRD - despite what the "specs" say - comes with the 16inch ("Mechanica" - optional on Liberty Sport models) wheels and 225/75/R16 tires....
And that the 2005 models have a new plastic kick plate.
And possibly that the Renegade models have different hoods and front grills... (flatter hoods, bigger grills with no fog lights, as they are on the bumper (and a slightly different bumper as well))
[URL=http://www.biodiesel.org]Biodiesel[/URL]: No war required.
Valkraider is offline   Reply With Quote
Old 09-12-2005, 07:41 PM   #15
clicktracy
In Oz we have a 2.5 I4 Turbo Diesel and I read somewhere that CRD stands for common rail direct
clicktracy is offline   Reply With Quote
Glock Forum
