Key Stuck In Ignition - JeepForum.com
post #1 of 17 Old 03-29-2008, 08:30 PM Thread Starter
bikinman1226
Key stuck in ignition?
Hey all, i was backing out of a driveway today and shifted from reverse to drive and heard a subtle clack type noise, ever since then i do not have to pull the shifter lever thing to engage gears it will slide through all of them, even in out and of park and the key will not come out of the ignition, any ideas on what that would be?? thanks.
bikinman1226 is offline
post #2 of 17 Old 03-29-2008, 09:03 PM
Busch2fan
2008 KK Liberty
There is a safety switch off the brake pedal that allows you to shift out of park. Maybe that broke. And if I remember it prevents one of removing the key unless car is in park. And on the other hand it could be some linkeage off the shifter.
Busch2fan is offline
post #3 of 17 Old 03-29-2008, 09:06 PM
jeepjeepster
Yea, there is a 'interlock' cable that runs from the shifter to the ignition and brake. I would say it came off.
This is there to make sure the shifter cannot be moves unless the brake is pressed and also makes sure the shifter is in P before you take the key out.
Edit: Busch beat me to it.
jeepjeepster is offline
post #4 of 17 Old 03-29-2008, 09:12 PM
rustym38a1
rustym38a1's Avatar
1953 M-38
You might be able to see something if you pop off your shifter cover plate. It just lifts up.
Just depends on which end broke or came off.
11 Wrangler Rubicon JK 'Call of Duty Black Ops Edition' 2 Door, 6 spd with Magnaflo exhaust, Banks Air intake, 34" Nitto Terra Grapplers
08 Liberty Limited KK- Sky Slider -Every option available at time (wife's car)
04 Sahara TJ- OME suspension, Borla Exhaust, Rusty's Skids, K&N, LED's, Pro Comp 31's
97 Wrangler SE TJ- This is our Trail Jeep. Yukon 4.88's, Powertrax Locker, 32" BFG KM2 tires, XRC/8 winch
53 Willys M38a1- Restored w/50cal Browning M2HB & 53 M100 1/4 ton Trailer fully loaded with gear!
13 Grand Cherokee Laredo WK2- company car
rustym38a1 is offline
post #5 of 17 Old 03-30-2008, 09:26 AM Thread Starter
bikinman1226
thanks guys, do you know if that is an expensive problem to fix? because i think that is what the problem is because the little lever i still do not know what it is called, but it will pull to a certain extent and then click all the way back
post #6 of 17 Old 03-30-2008, 12:39 PM
jeepjeepster
Depends on what the problem is. Lift the trim piece around the shift off and see if you can see anything. I believe you can see the shift cable with that off.
post #7 of 17 Old 07-18-2009, 09:47 AM
MoTheMan
I have this same issue I was able to see the cable and it is connected it just doesn't seem tight enough the plastic piece on the shifter doesn't engage all the way forward and I cant the key out. I can pull it forward manually and that will allow me to remove the key from the ignition. Any ideas on how much this is going to cost me to get fixed?
MoTheMan is offline
post #8 of 17 Old 08-16-2009, 07:40 AM
scraswell
@MoTheMan
Hey,
I have an '06 CRD and I encounted the same issue. I removed the entire floor console to inspect the area around the shifter. It looks like there is a solenoid that is supposed to push the plastic rocker all the way forward. I would guess that the solenoid has either failed, or the spring inside it has failed. The solenoid may or may not be replaceable, I'm not sure how Jeep sells the parts. They may only sell the entire assembly.
Anyhow, I've contacted my retailer to see what they think.
scraswell is offline
post #9 of 17 Old 08-18-2009, 01:30 PM
critter49
I've run into the same problem with my 2006 Liberty. Key will not always come out and you can go thru all the gears without pressing the gear shift button. It will lock in Park and you need to press the brake to release however. I definitely want to know a solution should someone find it.
critter49 is offline
post #10 of 17 Old 12-27-2009, 06:51 PM
Seaweed
Had the exact same problem with my 2006 Liberty. Here is what the invoice said: Replace steering column column, cable, and gear shift cable. Total $708. With 37,300 miles it has never been handled rough or driven off road.
Seaweed is offline
post #11 of 17 Old 12-27-2009, 07:03 PM
T-birdJunkie
2002 KJ Liberty
Seaweed, there is nothing in there that would cause your CD player to quit working.
Would you like an OE CD/cassette combo?
At any rate...to see what the problem is (expecting whole shifter assy to need replacement) force the shifter a bit more forward and see if it clicks. If it does, try taking the key out. If not...well...brake interlock cable is ThunderbirdJunkie's 2nd bet.
T-birdJunkie is offline
post #12 of 17 Old 12-27-2009, 08:09 PM
tjkj2002
2002 KJ Liberty
X3 on the shift interlock cable.
tjkj2002 is offline
post #13 of 17 Old 01-18-2010, 09:58 AM
jp7794
2006 KJ Liberty
Same exact issue.
Looks like an '06 problem. Has anyone tried to fix this themselves? I really don't have $700 to throw at the dealer right now. Any tips would be appreciated.
jp7794 is offline
post #14 of 17 Old 01-18-2010, 10:10 AM
jp7794
2006 KJ Liberty
Same exact issue. Shift interlock cable. Key will not come out and can move through the gears without pressing the gear shift button once it is out of park.
MOD NOTE: The thread I found was in the KK forum here. Please merge or move the topic as it is a KJ issue.
http://www.jeepforum.com/forum/f292/...nition-539432/
jp7794 is offline
post #15 of 17 Old 01-18-2010, 10:34 AM
jp7794
2006 KJ Liberty
Originally Posted by Gramps View Post
I see everybody is talking '06. Should this be in the KJ section?
PM sent to move thread.
jp7794 is offline
Have you ever gotten you KJ this stuck??? cj7Sswampers KJ Liberty Forum 9 08-02-2009 03:56 AM
What causes a KJ to get stuck in 4WD? AVR2 KJ Liberty Forum 40 11-17-2008 12:26 PM
Almost got stuck! panthermark KJ Liberty Forum 5 04-07-2008 02:06 AM
Tailgate stuck callaway KJ Liberty Forum 2 02-18-2008 03:41 PM
My ignition switch is stuck and trying to change out. bradsy KJ Liberty Forum 4 05-27-2007 04:26 PM
