Just changed my alternator and now I'm loosing power. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Just changed my alternator and now I'm loosing power.
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiIRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK
Unread 08-20-2012, 12:43 PM   #1
robodiaz
I have a 2003, 3.7L liberty and I just changed my alternator over the weekend.
I had a choice of two alternators at Auto Zone, the difference being in amperage. A 136 or 160 amps. The guy couldn't tell which one I previously had so I opted for the larger one because he said it wouldn't make a difference since I'm not running alot of extra electrical devices.
Took it and installed it, test drove it for about 20 min. everything was fine.
Then today I drove to work on the highway and when I got up to around 70mph I noticed a slight loss in power and the engine just wasn't running as smoothly. Drove up a hill and there was a definite loss in power.
Is using the higher amped alternator causing my power loss? I've checked the belt and the connections to the alternator and it looks good.
Should I have autozone test out my car again?
Thanks!
RD
robodiaz is offline   Reply With Quote Quick reply to this message
Unread 08-21-2012, 01:03 AM   #2
Billwill
2002 KJ Liberty
Thanks!
RD
Is the alternator charging?....put a voltmeter over the battery...should read about 13.4 volts at idle.
A larger alternator means it has the ability to supply more amperage if needed; under normal running it will supply the same amount of current as a smaller amperage alternator will.
There should be the main large lead on the rear of the alternator and a smaller plug with two thin leads plugged in.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline   Reply With Quote Quick reply to this message
Unread 08-21-2012, 12:41 PM   #3
robodiaz
Fixed so far ...
Thanks Billwill for your feedback. I didn't get chance to run the voltmeter on it but I probably will just in case. They did test the alternator before I bought it though.
So I read somewhere online (sorry I can't remember where) about someone who was having some weird electrical issue on their car. They had to disconnect the battery for 30 min. Then hook everything back up and let the car run idle for about 10 min. They mentioned something about the computer having to get used to the new system or something like that (sorry I know it's not very helpful).
I did the same and it's worked so far. I ran it on the highway and up hills trying to recreate the problem. Everythings been good so far.
alternator , power loss
