Quantcast Jeep YJ 15 x 7s on a 2002 Liberty - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Jeep YJ 15 x 7s on a 2002 Liberty
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 04-24-2008, 11:25 AM   #1
cushtech
Any issues with putting a set of 15 x 7 Jeep Wrangler (YJ) alloy rims on an 02 Liberty? Tires are 235/75/15 the rims are OEM Jeep 5 spoke alloys.
cushtech is offline   Reply With Quote
Old 04-24-2008, 01:20 PM   #2
aszalan
should be no problem since they have the same bolt pattern, and the 235/75/15 is no larger than the largest tire that can fit on a non-lifted KJ (245-70/16)
http://www.discountedwheelwarehouse.com/Jeep___Vehicle_Bolt_Pattern_Reference.cfm
Originally Posted by shocka59 View Post
Go ahead and put a locker in the 35. I feel like it helps to keep you from breaking in certian situations.
aszalan is offline   Reply With Quote
Old 04-24-2008, 01:31 PM   #3
festerw
2007 MK Patriot
IIRC the 15's will not clear the brake calipers.
Her's - 2007 Jeep Patriot Sport 4x4
Mine - 2005 Jeep Grand Cherokee Laredo 3.7 4x4
festerw is offline   Reply With Quote
Old 04-24-2008, 01:41 PM   #4
aszalan
you are right, I guess only a few 15" wheels will fit without interfering with the brake calipers.
15" vs. 16" Wheels
With a 17" wheel there is a limited selection of all-terrain tires available. A popular upgrade for the lifted Liberty is stock 16x8" Jeep Wrangler Rubicion wheels (Moab Wheels) with 5" of backspacing and 245/75R16 Goodyear MTR Tires. The Liberty's stock 16x7" wheel can fit a 10.5" wide tire with no problems. Only a few 15" wheels can fit on the Liberty without interfering with the brake caliper. Some other choices are the Rock Crawler Xtreme Steel Wheels with a backspacing of 4.5" or 3.75" or Cragar Wheels with 4-4.5" of backspacing. A backspacing of under 4" will work, but is not recommended because rubbing on suspension components may occur.
http://en.wikibooks.org/wiki/Jeep_Liberty/Tires_&_Rims
Old 06-27-2008, 07:06 AM   #5
PSYCH0
PSYCH0's Avatar
2009 JK Wrangler
Would the 15" wheels work if you use wheel spacers?
2009 Jeep Wrangler JK, 2-Door, Soft Top, Automatic, Black Procomp Aluminum Wheels with 315x75R16 Goodyear Wrangler Duratracs, 2" Black Diamond Lift, JKS Adjustable Track Bars, Smittybilt Rock Rails
PSYCH0 is offline   Reply With Quote
Glock Forum
