Quantcast Jeep won't start! 02 Liberty - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Jeep won't start! 02 Liberty
Old 09-07-2006, 03:39 PM   #1
Xerxes600rr
I need help. I turned my ignition to the on position w/o starting my jeep. I extracted a cd and everything was fine. Now i can turn it to accessory and everything works. When i try to turn it over nothing works. My battery cell is green, although it's 4.5 y/o and it will start when it is jumped. I drove it for 30 min turned it off and the same thing. Sounds like the altenator with the battery not holding the charge, however this is where it gets confusing. If i open the door or try to turn the headlights on, anything like that, the tailgate door lock or window latch goes crazy, it won't stop going. I'm afraid i'm going to burn my motor out. Could it be a faulty circuit relay/fuse/battery/ or altenator. Anything would help, don't have money to take it in right now. Bought too much parts. I'm out of ideas.
Xerxes600rr is offline   Reply With Quote
Old 09-07-2006, 04:09 PM   #2
jeepjeepster
Bad battery. If it will run for 30minutes, the alternator is fine.
jeepjeepster is offline   Reply With Quote
Old 09-07-2006, 04:44 PM   #3
skleinsmith
Also, some of the "switches/relays" go crazy when they do not get enough voltage, the click in and out. I would try a new Battery 1st, a good parts store can charge and load test yours to make sure it is not the alternator.
Shawn Kleinsmith
Igo, CA (Near Redding)
2004 Liberty (3.6 v6 gas) - Rocky Mountain Edit - Silver/charcoal
skleinsmith is offline   Reply With Quote
Old 09-10-2006, 11:51 AM   #4
lucas/liberty
how old is the battery, and where do you live(elevation wise), replace the battery first...
...you dont stop playing just because you get old, you get old because you stop playing...
...If a man speaks in the woods where there is no woman to hear him, is he still wrong?
Wife=2002 jeep liberty sports traded it in for an RX330 lexus
===2007 nissan Xterra X
lucas/liberty is offline   Reply With Quote
Old 09-10-2006, 01:59 PM   #5
CRD4Liberty
Pull out your mutlimetter with the engine running and the voltage should be 14.2 to 13.8 VDC. If it is the alternator is good, battery isn't. Could also be a bad/dirty battery connection though I doubt it, as when you jumpstart a battery you are bypassing the important battery post to battery lead connection that may need cleaned or tightened.
CRD4Liberty is offline   Reply With Quote
Glock Forum
