Jeep Liberty Speedometer - JeepForum.com
post #1 of 20 Old 02-04-2005, 10:31 AM Thread Starter
jlynn
Hello,
I have a 2002 jeep liberty sport.The speedometer on my kj has started to bounce at no matter what the speed. Has anyone else had a problem with a bouncing speedometer?
Thanx
jlynn
jlynn is offline
post #2 of 20 Old 02-04-2005, 01:56 PM
swyszomirski
I had this problem in my old FORD SHO, the linkage was coming loose, and eventually came loose from the tranny. Either take it to the stealership or look in your manual as to where it connects and check it yourself.
2004 Liberty (4x4) 5spd. - Rusty's air tube, light bar, front hitch with Mile Marker 8000, air horns, Megawarrior roof basket and fog lights. Sirius
Fighter Jet grip stick for a shifter....
swyszomirski is offline
post #3 of 20 Old 02-04-2005, 03:04 PM
madmanfrommars
madmanfrommars's Avatar
Happened to me once (not in a jeep), except every dial on the instrument cluster started to bounce crazily. They had to replace the entire unit.
madmanfrommars is offline
post #4 of 20 Old 02-07-2005, 12:11 PM
WhiteWater
Had that happen on a friends. Turns out the battery was crappin' out. Put a new one in and it was cured. Now I have no idea why a battery going out would cause this but you might want to get it load tested.
WhiteWater is offline
post #5 of 20 Old 02-15-2005, 05:42 PM
kjnut
Liberty Speedometer Fix
I have a 2002 Liberty the speedometer went nuts on me... then quit....then started working fine...then went nuts again...went through this process several times(over a few days time)Then quit for good.I replaced the transmission speed sensor(advice from Jeep dealer)didn't help.Then changed the speedometer sensor(also on the transmission)I noticed during changing it that thewires going to this sensoer had been frayed from rubbing on the emergency brake cable...I repaired the wire and rerouted them under the cable.Speedometer works fine now with no sign of trouble.Sensor still need replaced due to shorting out.I don't know why they designed it to go up and over the brake cable and along the frame.I could not get an anwser from Jeep.I hope this helps.Please get the word out elswhere if anyone has this problem.
kjnut is offline
post #6 of 20 Old 02-15-2005, 08:12 PM
ZR7 Ken
ZR7 Ken's Avatar
"Then changed the speedometer sensor(also on the transmission)"
Correct me if I'm wrong, but I believe the sensor you're referring to is on the top of the rear differential, not on the transmission.
The emergency brake cable rub is something I've seen on many Libertys. Very poor planning, as far as I'm concerned.
ZR7 Ken is offline
post #7 of 20 Old 02-26-2007, 10:51 PM
red125
I just had my speedometer go a 2nd time on my 2002 Liberty Sport. First time it was $130 at the dealership to repair the wire. This time, they say they have to replace the wiring harness and the speed sensor for a cost of around $900. They also told me that a mouse or a squirrel must have chewed the wire!
red125 is offline
post #8 of 20 Old 11-24-2007, 03:46 AM
ragoo43
02 Liberty speedometer issue
I have the same problem. The speedometer stopped working last year. Took back to the dealer ( it was used 02 Liberty still under 30 day warranty) they fixed it no charge said wire was loose. Then a week ago 11/15/07 same thing so I started checking it myself. Found out the wire to the speed sensor that controls the speedometer on the rear axle was rubbing on the e -brake cable.
it was spliced several times must have happenend more than once or twice. I cut the wires took the part to my local junkyard $15 later it was working fine.ragoo_46@yahoo.com for a pic of the wires. ragoo43
ragoo43 is offline
post #9 of 20 Old 08-09-2010, 04:34 PM
b_bittick
Im having the same problem with the speedometer. I have replaced the sensor and looked at the wire that controls the speedometer and it is not frayed or spliced or anything. What else could this be!!! I am moving to FL in two days, i really need to figure this out.
b_bittick is offline
post #10 of 20 Old 03-28-2012, 01:20 PM
bowhunter23
2002 KK Liberty
Speedometer
Hello i just bought my 2002 jeep liberty and the darn speedometer went out in it!! About a week after it went out i noticed any time i slow down the jeep will stall out. After doing some research i found out that the wires to the speedometer will make the jeep stall out. Is this true? and where at is the wires for the speedometer? is there any diagrams or anything like that i can use? i need some help here im in college and a pizza delivery driver i need my jeep!!!
bowhunter23 is offline
post #11 of 20 Old 03-28-2012, 02:20 PM
RankinD
2003 KJ Liberty
This is usually an easy fix. The speedometer gets it signal from the speed sensor on the top of the rear differential. Most of the time the wires are rotted or broken and you just need to put a new plug on it. Can get it at the parts place of the dealership for very cheap and takes about 10 minutes to do. Did it to mine and fixed the problem.
RankinD is offline
post #12 of 20 Old 03-29-2012, 06:14 AM
bowhunter23
2002 KK Liberty
Okay last night i looked at the sensor and found out the wires are broke coming out of it on the left side i need to get new wires put in it? or does the new sensor have the wires on it?
post #13 of 20 Old 03-29-2012, 09:07 AM
RankinD
2003 KJ Liberty
The sensor itself should be fine. It doesn't have its own wires coming out. What has broke is the wires coming out of the plug that goes into the sensor. The dealership's parts dept. will have a new plug for like $10. Dont get the sensor, just the plug repair kit / new plug. Unplug the one that is on it, cut the wires. Use a soldering gun to solder the new plug on, and plug it back in. It took me about 10 minutes to fix mine. The one I got from the dealership came with its own heat shrink tubes that had some sort of sealing glue inside of them. All straight forward stuff. Just make sure you pay close attention to which wire goes to which connector, don't cross them.
I also doubt that it is causing the jeep to stall out. the transmission has its own speed sensors, separate from the one on the rear differential. If it is stalling out when you come to a stop, clean out your idle air control motor and intake throttle body. Very easy and well documented stuff. Takes about 1 hour.
RankinD is offline
post #14 of 20 Old 04-10-2012, 06:14 AM
bowhunter23
2002 KK Liberty
Now my dad put a new sensor on it and also a new plug he rewired it too he has also cleaned out the fluids in the rear diff and the speedometer still wont work. is there anything else to do?
post #15 of 20 Old 04-10-2012, 09:01 AM
RankinD
2003 KJ Liberty
Other than checking for frayed wires, I have no idea.
RankinD is offline
02 Liberty Speedometer Fluctuating GotBeat5.0 KJ Liberty Forum 1 01-21-2010 04:50 PM
'02 KJ Liberty Speedometer Problem jeepcrazy9 KJ Liberty Forum 8 08-27-2009 12:40 AM
Liberty Speedometer Error dabincharlotte KJ Liberty Forum 14 11-14-2008 03:50 PM
2003 Liberty Speedometer and Odometer Dead kathi22 KJ Liberty Forum 1 02-24-2008 04:58 PM
2002 Liberty - ABS & Speedometer Issues JeepFun74 KJ Liberty Forum 1 11-24-2006 03:52 PM
