Jeep Liberty P2096 code - JeepForum.com
post #1 of 11 Old 03-15-2012, 10:15 AM Thread Starter
bassnleo
2005 KJ Liberty
My C.E.L came on recently and it came up with the code P2096. I brought it to the mechanic and they told me it was the catalytic converter. After i heard the price i decided i would try to do it myself, i have basic knowledge of automobiles and tools. I did my brakes recently without a problem but im no ASE Mechanic. i called auto zone and the converter itself is 433 and the whole y pipe assembly is 800. Do i need to do the whole thing or will one work? how do i know which one to replace? Also do the o2 sensors need to be replaced as well? any information that could help will be greatly appreciated.
thanks
-matt-
bassnleo is offline
post #2 of 11 Old 03-15-2012, 11:04 AM
tjkj2002
2002 KJ Liberty
Do you have a welder and know how to use it? If not you will need the whole y-pipe assembly.
Just remember aftermarket cats are not nearly the same quality as OEM cats and why aftermarket cats are not 50 state legal.If your under 8 years and 80,000 miles just take it to the dealership since the cats are warrantied for that time.
But that code is not for bad cat's,the most common issues that set that code are bad downstream O2 sensors and/or bad upstream O2 sensors, and exhuast leaks.
I would get a better diagnoses before replacing the cats and if it is just a O2 sensor make sure it is not a Bosch O2 sensor,use only OEM or NTK O2 sensors in your Jeep.
tjkj2002 is offline
post #3 of 11 Old 03-15-2012, 01:59 PM
richd
2008 KK Liberty
I agree with tjkj,this code doesnt show the cat as one of the causes. Engine Mechanical problem,and fuel contamination will also set this code.
richd is offline
post #4 of 11 Old 03-15-2012, 04:57 PM Thread Starter
bassnleo
2005 KJ Liberty
Thank you for the quick response! I thought it was the cat because when you hit it you can hear something almost rattling around inside it. It sounds the same on each side is this normal, also at idle it rattles a little. I do have a welder and i can use it if needed. Can i use a non California compliant cat like this http://www.jcwhitney.com/high-capaci...rid=c10821u0j1 ?
thanks
matt
bassnleo is offline
post #5 of 11 Old 03-15-2012, 06:26 PM
streetglideok
2005 KJ Liberty
Yep, tjkj hit it dead on. Thats not a cat code, like say p0420 and p0430 are, and even those arent always for bads cats. From my experience, if the mechanic says it jumped time, the cats are plugged, or it needs a pcm, theres a strong possibility the guy is clueless and lost, and is trying to flush it.
streetglideok is offline
post #6 of 11 Old 03-16-2012, 08:46 PM Thread Starter
bassnleo
2005 KJ Liberty
I went to NAPA and got a NTK Downstream o2 sensor for the drivers side. Put it in, unhooked the battery to reset the light, and drove about 30 miles. No CEL so far hopefully it stays off.
thanks for the help
-matt-
bassnleo is offline
post #7 of 11 Old 03-19-2012, 07:18 PM Thread Starter
bassnleo
2005 KJ Liberty
I just got my Inspection Sticker and less than 10 miles later i get the P 0420. The cat rattles like there is something inside it bouncing around. How long can i drive like this? will it effect anything else?
thanks
-matt-
bassnleo is offline
post #8 of 11 Old 03-19-2012, 07:47 PM
richd
2008 KK Liberty
thanks
-matt-
Just like streetglideok said P0420 is a code that can be a bad converter,so if it rattles and now have a code for possible bad cats,then I say replace it.You never answered if your under 80k,if you do its under Emission Warranty, like tjkj said.
richd is offline
post #9 of 11 Old 03-19-2012, 08:15 PM
streetglideok
2005 KJ Liberty
If it is rattling inside, then its at risk of breaking up and causing a major exhaust restriction, and cause a slew of other problems. Longer you wait, the richer we'll get fixing your jeep man. Get it in asap
post #10 of 11 Old 03-19-2012, 08:29 PM Thread Starter
bassnleo
2005 KJ Liberty
Ok thanks. I have 135,000 so I'm well past the emissions warranty. Ill probably buy the whole y pipe and do it myself. It looks like there are only 2 bolts on each side connecting it to the headers maybe? And 2 bolts connecting the back to the muffler. It shouldn't be too hard. Any tips?
Thanks
Matt
bassnleo is offline
post #11 of 11 Old 03-20-2012, 06:46 AM
streetglideok
2005 KJ Liberty
Yeah since you live in the rust belt, lots of penetrating oil, and wd40 doesnt count. Soak the bolts, and cross your fingers it comes apart.
Jeep cherokee (Liberty) radio code?? Jxedwards KJ Liberty Forum 23 06-11-2016 12:40 AM
P2096 code - now what should be replaced? Turbobearcat KJ Liberty Forum 8 01-27-2012 10:02 AM
Fault code p1281 for 02 jeep liberty angeliqued99 KJ Liberty Forum 1 10-10-2010 06:59 PM
Jeep Liberty Diesel code P0069 racecarricky KJ Liberty Forum 8 10-06-2010 05:35 PM
P0876 Transmission Code 02 Jeep Liberty Savage46 KJ Liberty Forum 1 06-09-2010 07:12 PM
