Jeep Liberty Diesel Problem. - JeepForum.com
post #1 of 8 Old 09-10-2005, 01:11 PM Thread Starter
nickaway
I have a Jeep Liberty Diesel with about 1000 miles on the clock. I like it but I have had a couple of problems with it. Twice when after filling up and having done about 20 to 30 miles then stopping, when I get in again to start the truck it will only run on about two cylinders. The vehicle will slowly creep through the gears and feels like it will stop any moment, clattering and creeping along. I stop and turn the truck off, phone the dealer who will ask me to get it back to the dealership. When I go to try and take the truck back it runs perfect and the dealer can not find what the problem is. Here are the details: I fill the truck when the fuel light comes on. When the problem occurs no lights come on the dash and the dealer says no problems are showing on the computer. Have any others experienced this problem and has anyone any idea what it could be. Regards Nickaway
nickaway is offline
post #2 of 8 Old 09-10-2005, 01:37 PM
Blue79
Does it hang at like 20mph and about 3000rpm?
Blue79 is offline
post #3 of 8 Old 09-10-2005, 03:25 PM
Diesel Inferno
It sounds like you might have air in the fuel line. It may have to be purged and primed. Maybe the air is out now however, so wait and see if it happens again.
Downers Grove Illinois
2005 Inferno Red Sport CRD
Diesel Inferno is offline
post #4 of 8 Old 09-11-2005, 03:46 PM
wolcott
I noticed the same problem with my CRD. I'd been driving at a steady 60 mph, I stopped to get an item from the back, and when I restarted it, it did exactly as you described. I pulled over, shut it off, checked under the hood (all OK) and then restarted it. It ran beautifully. No check engine lights came on, and it had 1/4 tank of fuel. This is the first time this has happened, mileage is 2000. Let me know if you find out anything new about this. I've had air in the lines in other diesels and it did not sound like this. It felt more like a computer malfunction, especially with the restarting beautifully. The other computer diesel I had, a GMC 6.5, acted this way when the computer went into the "limp home" mode.
CRD Limited, use standard diesel with Stanadyne Performance additive, and have a Mann Provent installed.
wolcott is offline
post #5 of 8 Old 09-13-2005, 03:47 PM Thread Starter
nickaway
I will keep you posted if I find anything out. I just filled up again and all is OK. I use the truck a lot on the beaches and a long walk from civilization so it had me a bit on edge. The fuel consumption over the first 1000 miles was just less than 20mpg with a couple of hundred being on the beach. I have also noticed an over heating problem when she is pulling in soft sand over about two miles. Thanks for your input. Regards Nickaway
http://img.photobucket.com/albums/v6...nick090305.jpg
nickaway is offline
post #6 of 8 Old 09-13-2005, 06:57 PM
WXman
This happened to my CRD at about 3,500 miles. Started bucking and kicking and wouldn't hardly run. I pulled over and shut it off. Tried to start, wouldn't run. Finally got it started and it ran fine after that. My dealer looked at it, and reflashed the computer. No trouble since then and I'm at 8,500 miles.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #7 of 8 Old 06-19-2017, 08:36 AM
wjkuhl
have a liberty jeep 2.8 diesel 125k miles just stopped like turn o0ff key then will start after 10 15 min run maybe 15 and stop again like a breaker goes looked in box fined nothing is there a breaker for just the fuel supply
wjkuhl is offline
post #8 of 8 Old 06-21-2017, 11:37 PM
Billwill
2002 KJ Liberty
You need to try and have any stored codes read out.
Common problems are the cam and crank sensors failing....especially as they warm up. Replace only with OEM parts.
Fuel problems such as air in fuel head do not always post any errors though.
If you have not replaced the fuel filter yet then I suggest you do so and pump the fuel head to get air out the system.
Most CRD owners have replaced the fuel filter head with a Raycor unit which is a lot better and some have fitted lift pumps in the fuel tank as the CRD does not come standards with a pump.
Best place for CRD problems is the "Liberty CRD Love that Torque" section at:http://lostjeeps.com/forum .Lots of CRD experts there!
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
Jeep Liberty Diesel code P0069 racecarricky KJ Liberty Forum 8 10-06-2010 05:35 PM
2005 Jeep Liberty CRD 4x4 (some diesel questions) cherokeeKID KJ Liberty Forum 1 01-22-2010 10:13 PM
Jeep Liberty Diesel Removal... FastZFunMJ KJ Liberty Forum 1 05-20-2009 09:19 AM
Jeep Kills Diesel Liberty in U.S. grogie KJ Liberty Forum 33 06-21-2006 08:12 AM
DR PERFORMANCE Pred For 2005-06 Jeep Liberty Diesel cartec01 KJ Liberty Forum 3 03-28-2006 09:31 PM
