Jeep Liberty Diesel code P0069 - JeepForum.com
post #1 of 9 Old 10-29-2008, 07:06 AM Thread Starter
racecarricky
2006 KJ Liberty
We have been having several problems with the jeep all related to code P0069 which is supposedly a barometric pressure correlation. Got the part from the dealer (05101120-AB Sensor) my husband replaced it and since it has been 28 days later and check engine light is back on with the same code. How does this happen? Is it really possible that I got a faulty sensor or is this a common problem with the crd jeep.
Thanks
racecarricky is offline
post #2 of 9 Old 10-29-2008, 07:57 AM
merlinTec
merlinTec's Avatar
Hi
I will need to check but I believe the barometric pressure sensor is part of the ECM (engine module) and not a part you could change.
Not looked up your part number yet to see what you have change but don't think it was the pressure sensor.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 9 Old 10-29-2008, 09:11 AM
gmctd
2005 KJ Liberty
Pull the MAP sensor and clean the EGR crud - that rectangular black-plastic sensor is at the top-rear of the head adjacent the fuel filter, attached with a single hex-head bolt, four-wire connector - that other large-hex three-wire sensor back there is the Rail-Pressure Sensor, screwed into the rail, and another at the rear of the rail, the RP Solenoid - don't even mess with them.......................
96 Dodge 3500 CTD, unseemly unstock
If it's a Diesel thing, I do understand....
'05 CRD; INMOTION ST-II; EDGE Trail; Pricol Boost, EGT, Rail Press, Trans Temp; SEGR; Provent; Magnaflow;
2.5" Daystar f, OME r; Al's arms, Moogs; Ranchos; Rubicons, 2.55 Gy's; Suncoast T\C, Transgo
'06 Cummins lift pump module, Fuel Manager\Filter, Filterminder
Four in a row really makes it go
gmctd is offline
post #4 of 9 Old 10-30-2008, 07:11 AM Thread Starter
racecarricky
2006 KJ Liberty
Thanks gmctd I will get my husband to try that. Of course after doing some running around now the check engine light is off. We are willing to try anything at this point as the check engine light seems to come on and go off so often with our vehicle. Hence why we know have a code reader instead of having to run to the dealer each time as the light is usually off by the time it reaches them.
post #5 of 9 Old 02-01-2009, 02:38 PM
jpliberty
2006 KJ Liberty
liberty crd check engine light
Did you ever find out the cause of the check engine light coming on and off?
Thanks.
jpliberty is offline
post #6 of 9 Old 12-30-2009, 06:58 PM
ff1538
HELP crd P0069
Hi anyone have any information on error code P0069 Map/ Barometric Corelation i have cleaned the map but still have the code is the baro part of the ecu can it be fixed or is there a work around for it any help would be appreciated
ff1538 is offline
post #7 of 9 Old 01-02-2010, 02:32 PM
CATCRD
2005 KJ Liberty
That code is going to be related to the sensor plugged into the side of the air filter box. The connection may be bad or loose, or the sensor may be bad. Try reseating that plug or look for a new sensor.
CATCRD is offline
post #8 of 9 Old 01-25-2010, 11:32 AM
ff1538
P0069
Finally replaced the sensor on the side of the air box no cel for over a week
ff1538 is offline
post #9 of 9 Old 10-06-2010, 05:35 PM
HATEKIA
The same problem
Hi,
I have a same problem with KIA CAREN 2006 2.0 DIESEL, my partner took it to a local garage the error code was same P0069, and engine check light is flashing all the time. what is this sensor called exactly and where can i buy it from dont want to go dealer they charge to much for any work pleas help thank you
HATEKIA is offline
2005 Jeep Liberty CRD 4x4 (some diesel questions) cherokeeKID KJ Liberty Forum 1 01-22-2010 10:13 PM
Jeep Liberty Diesel Removal... FastZFunMJ KJ Liberty Forum 1 05-20-2009 09:19 AM
Jeep Kills Diesel Liberty in U.S. grogie KJ Liberty Forum 33 06-21-2006 08:12 AM
DR PERFORMANCE Pred For 2005-06 Jeep Liberty Diesel cartec01 KJ Liberty Forum 3 03-28-2006 09:31 PM
Jeep Liberty Diesel Problem. nickaway KJ Liberty Forum 5 09-13-2005 06:57 PM
