Jeep Liberty 2.8 L Diesel ETC Light Flashing! - JeepForum.com
post #1 of 21 Old 05-31-2010, 03:55 PM Thread Starter
raenram
Hi, I own a 2007 2.8 L Liberty, and I my ETC ligth is flashing, and it wont stop. The car is running fine, and it has no power issues that i know. I think it started after driving through water, and i tried to dry the brakes while i was accelerating
Any help??
Thanks
raenram is offline
post #2 of 21 Old 06-02-2010, 11:51 AM
95BadBoy
Most likely a wet or failed speed or ABS sensor (maybe wire?). Give it some time to completely dry out & see if it goes away.
Post back & let us know if things came back to life.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #3 of 21 Old 06-02-2010, 02:10 PM
T-birdJunkie
2002 KJ Liberty
Going to second the wheelspeed sensors; That or a damaged wheelspeed sensor wire.
T-birdJunkie is offline
post #4 of 21 Old 06-04-2010, 02:48 PM Thread Starter
raenram
I took the jeep to a Jeep dealership, they checked the engine codes. Then they reseted the computer.
No flashing ETC light no more. Car works fine.
I recommend you guys a device called kiwi from PLX, its a OBD II system for the iphone. Very cool. I actually ordered one today to avoid more trips to the dealership. It can check engine codes, RPMs, boost pressure, and much more.
PLX Devices Inc.
Thanks!
raenram is offline
post #5 of 21 Old 06-04-2010, 05:02 PM
CATCRD
2005 KJ Liberty
The jeep is designed to do this. It has an electronic throttle pedal, so if the ECU sees acceleration and braking at the same time, it will throw a code after enough of it. That's why you didn't have any real driveability problems.
CATCRD is offline
post #6 of 21 Old 06-05-2010, 11:43 AM Thread Starter
raenram
UPDATE: ETC light started flashing again today. No check engine light. Car seems to work fine.
This is starting to make me think that there is something actually wrong in the car. I'm going to try to get an error code, from the dealership (but here in my country Jeep services are terrible...really for every car...).
Ideas? Please?
Thanks,
RR
raenram is offline
post #7 of 21 Old 06-05-2010, 11:48 AM Thread Starter
raenram
T-Bird Junkie: how do i check and replace wheelspeed sensors or the wheelspeed sensor wire?
raenram is offline
post #8 of 21 Old 06-05-2010, 03:12 PM
T-birdJunkie
2002 KJ Liberty
Check for continuity on the wheelspeed sensor wire. The sensor itself rarely goes bad, but they usually get gunked up.
Check the wire's insulation for any signs of stretching or wear. Don't remember if the KJ's wheel speed sensors are integral with the wire or not, TJKJ probably knows though. Hopefully he'll chime in.
post #9 of 21 Old 06-05-2010, 03:49 PM Thread Starter
raenram
Thank you, T-birdJunkie, I'm going to try to find the wheelspeed sensor wire, and give it a check, before taking it to the dealership.
raenram is offline
post #10 of 21 Old 06-05-2010, 04:41 PM
T-birdJunkie
2002 KJ Liberty
Good luck!
post #11 of 21 Old 06-07-2010, 12:49 PM
WXman
From what I've been told, an engine light is bad. A flashing engine light means go to the dealership immediately because something catastrophic is about to happen. I've never had a flashing light though.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #12 of 21 Old 06-07-2010, 01:33 PM
T-birdJunkie
2002 KJ Liberty
ETC is not the engine light.
post #13 of 21 Old 06-07-2010, 07:49 PM
WXman
OH yeah, it's not, is it? See, I don't have that light cause I have an '05.
WXman is offline
post #14 of 21 Old 06-07-2010, 08:50 PM Thread Starter
raenram
I have a 2007, and it has the engine and the ETC light, but ONLY the ETC light is on and flashing.
Maybe your ETC light is dead, give it a check.
Good luck.
raenram is offline
post #15 of 21 Old 06-07-2010, 09:37 PM
T-birdJunkie
2002 KJ Liberty
Excellent contribution
Jeep Liberty Diesel Problem. nickaway KJ Liberty Forum 7 06-21-2017 11:37 PM
Jeep Liberty Diesel code P0069 racecarricky KJ Liberty Forum 8 10-06-2010 05:35 PM
2005 Jeep Liberty CRD 4x4 (some diesel questions) cherokeeKID KJ Liberty Forum 1 01-22-2010 10:13 PM
Jeep Liberty Diesel Removal... FastZFunMJ KJ Liberty Forum 1 05-20-2009 09:19 AM
Jeep Kills Diesel Liberty in U.S. grogie KJ Liberty Forum 33 06-21-2006 08:12 AM
