Jeep Cherokee/Liberty 2.8 Diesel Battery - Which One? Got Battery Problems - JeepForum.com
post #1 of 6 Old 11-21-2012, 02:49 PM Thread Starter
Tobes
2004 KJ Liberty
Hi Everyone,
I just joined the forum, Im from the UK and have a CRD 2.8, I love her, but i have been having trouble with the battery for a while, Im not sure I have the correct size, does anyone know the optimum battery amperage and brand should be for my model.
The one I have now is 12V 69Ah 520A which isnt holding charge for that long, if I dont use the car for a few weeks the battery is dead if it is cold.
I think another problem is I just dont drive the car enough, so the battery is not getting much recharge.
Can Jeep experts shed some light for me I could do with some help
Many Thanks
Tobes is offline
post #2 of 6 Old 11-21-2012, 05:07 PM
95BadBoy
The Optima that came in the CRD's state side (05 & 06) - were 1000ca, 800cca, group 34R.
Mine has a charger / tender on the battery all the time, as it is not used daily and can sit for weeks. Many owners have reported a draw when their rig sits for extended periods of time. Low temps increase the drain.
Personally, if I were to replace today - it would be a Sears Platinum made by Odyssey (sp).
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #3 of 6 Old 11-21-2012, 11:58 PM
Billwill
2002 KJ Liberty
Originally Posted by Tobes View Post
Hi Everyone,
Many Thanks
Here in SA we do not have the wide range of buying options that our friends in the USA have.
When my battery need replacing...the last place I would go to is the Jeep agents.....I got one from a battery supplier that would normally fit the Mercedes ML 500 Diesel I think.
It is 750 CCA but is a bit longer in size so I had to modify the battery tray a bit.
I would suggest you visit a general battery supplier and see what they have that has a high CCA rating, fits into the battery tray, has the positive and negative terminals in the correct position and ideally is a sealed no-maintenance.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #4 of 6 Old 11-22-2012, 05:10 AM Thread Starter
Tobes
2004 KJ Liberty
Thanks again to you both, appreciate the advice, I reckon the battery I have no works but not for that long as its not powerful enough.
By the way, is 520A the same as 520cca Im over in the UK, so Im not used to all your terms, infact here in the UK my car is a Cherokee Sport CRD not a Liberty, actually prefer the name Cherokee
I purchased this the other day http://shop.wiltec.info/product_info...oster-430.html
I should have got it years ago, no more asking people to jump start me
Re: the optima, that is what was taken out, and like a chump I asked the local garage to replace the battery, they threw in a inferior battery, and I never got the optima back, but when I looked at buying the same make it was around 220 which was way too much for me at the time.
Well I have found this lovely forum now, so hope I can get some good advise to keep my lovely car running sweet.
Even though she cost's me a fortune to drive, I love her and dont want to part with her
All the best to you both
Tobes
Tobes is offline
post #5 of 6 Old 11-22-2012, 05:42 PM
95BadBoy
Your cold cranking amps (CCA) will usually be considerably less than warm static cranking amps (CA) if that helps in tracking down what you need in your location.
520ca is pretty darn low to keep these VM's starting like they should. What is the highest cca you can find in your area?
95BadBoy is offline
post #6 of 6 Old 11-28-2012, 04:21 PM Thread Starter
Tobes
2004 KJ Liberty
ah ok cold cranking amps, no wonder my car isnt starting with my rubbish battery, thanks for the info 95badboy, I need to brush up on my Jeep knowledge, hopefully people here can help me out.
Thanks
Tobes
Tobes is offline
