installing splash guards...How do I remove plastic rivet... - JeepForum.com
post #1 of 6 Old 01-28-2005, 01:50 PM Thread Starter
Dupe
Hi
I bought the mopar splash guards for my 02 sport. The directions are self explanitory with the exception of how to remove the plastic press-stud. Has anyone done this, i don't want to damage anything?
Thanks
Dupe is offline
post #2 of 6 Old 01-28-2005, 02:42 PM
Steven73
drilling through plastic rivets when installing splashguards
Originally Posted by Dupe
Hi
Thanks
I've done it, and it's really simple. First of all you should have received a set of picture instructions with the splashguards. Using the proper drill bit, just drill the plastic rivet right out. It just melts away under the drill bit, and is easily removed. Good luck with your installation, and remember to follow those instructions exactly, and you'll have no problems.
Steven73 is offline
post #3 of 6 Old 01-29-2005, 10:32 AM Thread Starter
Dupe
I guess I'm going to have to take the tire off then? I'll let you know how it goes
02 Sport, It's our mini TANK...
Dupe is offline
post #4 of 6 Old 01-29-2005, 01:25 PM
valvestem
valvestem's Avatar
Plastic Rivet
Use a pair "Sidecutter's" to get under the rivet head and simply snip it off. You may still have to remove the tire to drill some holes for the new mounting screws on the flaps. I started my mount last fall and stopped when I saw I'd have to remove the tire to fit a drill in the wheelwell.
valvestem is offline
post #5 of 6 Old 01-29-2005, 02:25 PM
Hand's End
If you turn your wheels like in the instructions you don't need to remove tires. I installed all four w/o removing any tires... They went on pretty quick and look good.
oh and use the diagnal cutters to snip off the rivets, quick and easy....
Hand's End is offline
post #6 of 6 Old 01-29-2005, 06:24 PM
Steven73
I never removed tires to put my splashguards on either. I almost did, and then decided to turn the front wheels to give more clearance. I never had a problem fitting my drill in place on either the front or the back. Just make sure you use the correct size drill bits. You are required to use different sizes, so make sure you follow the instructions to the letter. Mine went on, look good, and work well. It's one addition I made, that I'm super glad I did. It's already saved my rocker panels from getting gravel chipped. I'm also real happy with the front end bug/stone deflector. It was easy to install, looks good, and has saved my front end from getting gravel chipped as well. Very worthwhile investments.
Steven73 is offline
Affordable easy to install mud flaps/splash guards dac122 KJ Liberty Forum 2 07-10-2007 10:29 AM
Anyone order splash guards for their liberty? noahinBR KJ Liberty Forum 7 08-29-2006 10:48 PM
Bug deflector and splash guards BVCRD KJ Liberty Forum 14 03-17-2006 11:09 AM
Splash Guards for '05 Sport - Gray or Black? flyingpylon KJ Liberty Forum 3 02-04-2005 08:16 AM
Splash Guards daniel79 KJ Liberty Forum 7 06-23-2004 10:16 AM
