Installing a Frankenlift - Have Questions - JeepForum.com
post #1 of 2 Old 10-30-2010, 02:06 AM Thread Starter
ackeiyword
Junior Member
I'm installing a Frankenlift II Premium with Upper A's by Al's Jeepin'.
So far I have the driver's front installed and torqued. A few questions:
1.) With everything attached and back together and the front suspension in its lowest position that the stabilizer link will allow it to go, the upper A arm contacts the strut spring and the knuckle contacts the new strut lower side bumper. This is of course with rotors and calipers only on the wheel flange...no tire installed. Is this typical? I realize once the tire is on and the suspension is off of the jack stands, these areas will not be in contact, but what happens when I hit a deep run....won't these areas collide and possibly damage each other?
2.) Per the suspension condition above, the back surface of the clevis brakcet is almost in contact with the inner CV joint boot. There is around 1/8" or less gap between the two surfaces. I'm concerned that with the boot in motion, it may stretch and hit the clevis bracket. Is this also typical?
3.) Upon putting the driver's side battery back together, I noticed that the front differential vent tube does not fit on the the strut top bolts anymore as the new Frankenlift top studs are about 1/2" or so too short. How anyone figured out a solution to this?
Thanks in advance for all your help!!
ackeiyword is offline
post #2 of 2 Old 10-30-2010, 09:26 AM
tommudd
2004 KJ Liberty
AFTER ALIGNMENT AND THE SPRINGS SETTLING IN ALL WILL BE GOOD
ITS FINE AGAIN ONCE ITS ON THE GROUND AND BROKEN IN/ALIGNED IT WILL BE ok
WIRE TIE IT UP AS HIGH AS YOU CAN GET IT, DOESN'T HAVE TO GO BACK INTO THE SAME LOCATION
DO NOT INSTALL YOU SWAY BAR UNTIL IT IS SITTING ON THE GROUND WITH THE TIRES ON
other wise it preloads them and you have strange noises
same way with the UCAs if you torqued them with no weight on them you have preloaded them and now the bushing has to twist a lot to get into the right position
tommudd is offline
How To: Install Frankenlift II & Al's 4.5 Arms on CRD KJ 95BadBoy KJ Liberty Forum 7 02-19-2010 06:37 PM
Frankenlift II premium arrived today! redrubi1 KJ Liberty Forum 18 01-29-2010 10:45 PM
Question about Frankenlift or similiar lift kits conradz KJ Liberty Forum 2 05-05-2008 07:59 AM
Frankenlift photos of liberty? Huatulco KJ Liberty Forum 3 04-12-2007 09:14 PM
Installing Light Bar??? spoon KJ Liberty Forum 2 07-27-2004 04:39 PM
