Ignition switch problem - JeepForum.com
post #1 of 4 Old 12-14-2010, 08:38 PM Thread Starter
keiths
2003 KJ Liberty
2003 Liberty, 4wd, auto. Ignition switch only rotates to "run" position, won't go into "start". Tried the park lock cable, that seems good. Any clues? Also, the steering wheel won't lock (just bought this thing, not sure if that's normal). Everything seemed fine. Just came back from shopping, unloaded, parked, next day wouldn't start. Thanks...
keiths is offline
post #2 of 4 Old 12-15-2010, 10:38 PM
richd
2008 KK Liberty
You might need to check the brake transmission shift interlock cable adjustment.If it checks out, then could be you ignition lock cylinder.
richd is offline
post #3 of 4 Old 12-16-2010, 01:35 PM Thread Starter
keiths
2003 KJ Liberty
Removed lock cylinder, it seems smooth. Also, this was the first time the vehicle had been in 4wd in a couple of years, does that help diagnose?
keiths is offline
post #4 of 4 Old 12-16-2010, 10:30 PM
richd
2008 KK Liberty
I dont see how 4WD would cause this.Is it shifting out of park,and going in to park with out any problems?
richd is offline
Ignition backorder?? Tara22 KJ Liberty Forum 1 09-19-2010 06:52 PM
2005 liberty 3.7 serious ignition problem jjal881 KJ Liberty Forum 10 04-22-2010 06:47 PM
Big problem with Back-up switch need help ASAP 04LibertyRen KJ Liberty Forum 1 01-15-2010 08:44 PM
Ignition switch blueboy610 KJ Liberty Forum 2 11-18-2009 11:26 AM
My ignition switch is stuck and trying to change out. bradsy KJ Liberty Forum 4 05-27-2007 05:26 PM
