ignition switch need help please - JeepForum.com
post #1 of 12 Old 07-17-2013, 08:46 PM Thread Starter
billbo
my ignition switch has gone out on my 06 jeep liberty. the key turns but it`s like there are no tumblers in it, and my ignition is stuck in on position,the dash lights are on but no start. my ? is if i remove the switch can i start it with a screw driver?
billbo is offline
post #2 of 12 Old 07-18-2013, 01:54 AM
Billwill
2002 KJ Liberty
Yes you can start it with a small flat screwdriver.
Remove the covers from the steering wheel...two female Torx screws then remove the smaller Torx screw holding the ignition switch onto the actuator oin assembly. This small Torx screw requires a "security" male Torx bit which has a hole drilled in the center.
I am sure you will find that the "actuator assembly" has snapped off which is why the ignition switch does not move. This is plastic/zinc and has a habit of breaking off.
The Dealers do not stock this actuator assembly but will insist you buy the whole steering column assembly. Do a search here on "actuator assembly" or at the lostjeeps forum or the jeepkj forum and you will find where to buy the actuator assembly and how to replace it.
In the meantime, with the key in the ignition slot so that the steering lock is released and so the the key chip will activate SKIS if you have it fitted...turn the ignition switch with a small flat screwdriver and it should fire up.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #3 of 12 Old 07-18-2013, 06:09 AM
scottcason
2005 KJ Liberty
scottcason is offline
post #4 of 12 Old 07-18-2013, 11:15 AM
kjrenegade03
2003 KJ Liberty
Yup got mine at carquest. Dorman part# 924-704.
kjrenegade03 is offline
post #5 of 12 Old 07-18-2013, 12:12 PM Thread Starter
billbo
thanks fellows. im trying to get started on it, but i caint get the cover off, does anyone know what size the torx is or is it a special kind of torx?
billbo is offline
post #6 of 12 Old 07-18-2013, 12:17 PM Thread Starter
billbo
sorry please delete.
billbo is offline
post #7 of 12 Old 07-18-2013, 12:27 PM Thread Starter
billbo
what is SKIS
billbo is offline
post #8 of 12 Old 07-19-2013, 02:20 AM
Billwill
2002 KJ Liberty
what is SKIS
SKIS stands for something like Security Key Intruder System.
Some KJs only have it as an option, some have it standard.
You will Know if you have it installed if when you turn on the ignition a "KEY" symbol with a line through it light up in amber for a few seconds.
SKIS systems have a coded chip inbedded in the plastic of the key...when the key is inserted into the ignition key slot the chip sends a code to a SKIM module which sits just below the key barrel on the steering shaft...this SKIM module has a wire loop going around the key slot and picks up the code from the chip in the key.
The code is sent to the PCM/ECM and if the PCM/ECM is happy with the code the "key" symbol goes out and you can start the Jeep.
This prevents thieves trying to hot-wire the ignition or use a copied metal key to start the Jeep.
So if you have SKIS installed then you have to have the chipped key in the ignition slot while you turn the ignition switch with a screwdriver or the engine will not start.
Billwill is offline
post #9 of 12 Old 07-19-2013, 06:42 AM
scottcason
2005 KJ Liberty
Check out this video if you have not already. Did mine in about an hour.
https://www.youtube.com/watch?v=7SKQpbn9Zjo
post #10 of 12 Old 07-19-2013, 09:16 PM Thread Starter
billbo
thanks alot everyone i got the actuator assembly today, going to install it tomorrow.
billbo is offline
post #11 of 12 Old 01-27-2016, 01:42 AM
corrie007
corrie
hi,
my jeep cherokee 2.8 crd 2007 pcmecm part nr 05187221AB burnt out.
where can i buy one please?
corrie007 is offline
post #12 of 12 Old 01-29-2016, 10:58 PM
Billwill
2002 KJ Liberty
Originally Posted by corrie007 View Post
hi,
Where are you located? Overseas somewhere obviously.
Why do you think the ECM is burnt out?
Billwill is offline
