i need help with my 2005 jeep liberty crd please. - JeepForum.com
post #1 of 5 Old 05-15-2010, 03:43 PM Thread Starter
twirlymaster
2005 KJ Liberty
hello guys. i have 2 vw diesels and love them. and had 1 lincoln navigator that got 10mpg. i needed something better in mpg to tow the jet skis to the shore every weekend and i just today picked up a 2005 jeep liberty crd with a 115k miles from an auction. theirs no service records for this. and i want to change the timing belt and all the other maintenance things i need to do. not sure what they are, i hope some of you guys can help. and i need a mechanic that has dealt with this motor as well. i live in philadelphia but i have no problems traveling even 3 hours if i have to, new jersey,deleware,pa,maryland. new york
twirlymaster is offline
post #2 of 5 Old 05-15-2010, 07:59 PM
95BadBoy
First post - welcome to JF
You can get records for whatever has been done at a dealer by getting your vin number and having them run a VIP report on it. It will tell you at least whatever has been done in it's life at a Jeep dealership. You for sure do want to get the timing belt and the related items replaced. Can't recommend anywhere as I'm up on the northern plains. Here is a cut and paste of most of the part numbers for the timing belt change from moparonline parts.
5142579AA - Timing belt - $133.09
5142798AA - Tensioner - $72.54
5142573AA - Idler pulley (2) - $99.10
5066921AA - Timing cover Gasket - $11.88
5159019AA - Water pump O-ring #2 - $3.96
4864575 - Water pump Gasket - $2.25
5142601AA - Thermostat - $93.49
5066806AA - Thermostat gasket - $1.76
5142985AA - Water pump - $153.99
Sub Total $572.06
Shipping $29.95
Total $602.01
One of the other things you will want to do soon - is get the EGR taken care of. Kinda spendy if one of those fails on you - which is quite common. Quickest and for now the best way to do that would be through a Green Diesel Engineering (GDE) tune. It will take care of that and add quite a few other enhancements as well.
Green Diesel Engineering - Jeep Performance ECU Chip Tuner
Hope that is of some help.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #3 of 5 Old 05-15-2010, 08:08 PM Thread Starter
twirlymaster
2005 KJ Liberty
thanks alot. i guess you recommend all oem parts. no aftermarket. ill order those items soon all i need is a trusting mechanic. i hope someone on this forum can help me with that. their should be quite a few crd's in the northeast.
post #4 of 5 Old 05-15-2010, 09:39 PM
95BadBoy
For what you need to do, yes - stay with OEM for the timing belt parts. Give it some time and hopefully someone in your area will chime in for a trusted shop and/or mechanic. Most of the dealers are pretty clueless on these VM motors.
Tranny fluid and filter, diffs, and transfer case fluids most likely are overdue for changes too. Tranny have a dealer do, the others are real easy - I would say do those yourself.
95BadBoy is offline
post #5 of 5 Old 05-29-2010, 11:01 PM
cowpie01
2006 KJ Liberty
If you check for a shop that specializes in European auto repair, you should find a competent mechanic that would have no problem with doing the CRD. Go online and check for parts at one of many sources. You can save a grip of cash that way.
I'll second the comment on doing the transfer case and diffs yourself. Very easy. Front diff and transfer are simple drain and fill. The rear diff is a cover removal process. Most would use RTV on the cover reinstall, but I would highly recommend a lubelocker gasket. LubeLocker - Differential Gaskets You want the Chrysler 8.25 gasket. They are often reusable as well. I have reused my Lubelocker 3 times now with no leaks. Sure makes a messy job sooooo much easier.
On engine oil changes, definately do them yourself!!! The pan plug is very easy to strip out. Many shops will mess them up. Not sure if you can still get a Fumoto drain valve for the CRD, but that would be a very wise investment. Do not trust your engine oil changes to a dealer or quick lube on this engine.
Environmentalist Green + Socialist Red = Facist Brown
cowpie01 is offline
crd , diesel , jeep , liberty , mechanic
Problems with 2005 Jeep Liberty aquaman_06 KJ Liberty Forum 7 07-19-2015 06:30 PM
2005 jeep liberty crd? POTBSS KJ Liberty Forum 37 06-05-2015 05:16 PM
2005 Jeep Liberty CD Player archbarb KJ Liberty Forum 4 03-19-2012 08:06 AM
2005 Jeep Liberty Renegade wvtj33's KJ Liberty Forum 2 01-01-2006 11:58 AM
2005 Jeep Liberty CRD Review jay_bird KJ Liberty Forum 5 12-15-2004 06:07 AM
