I have a 05 liberty CRD with a no start condition - JeepForum.com
post #1 of 15 Old 09-19-2009, 09:34 AM Thread Starter
inpursole
2005 KJ Liberty
I have a 2005 liberty 2.8 CRD it doesn't want to start it has no DTC's. Fuel is good clean and no air in lines no matter what I do I can't get it started
inpursole is offline
post #2 of 15 Old 09-19-2009, 11:37 AM
goatscrd
Does it crank?
goatscrd is offline
post #3 of 15 Old 09-19-2009, 11:50 AM Thread Starter
inpursole
2005 KJ Liberty
yes cranks fine just doesn't start
post #4 of 15 Old 09-19-2009, 12:09 PM
CATCRD
2005 KJ Liberty
The ECU is looking for signals from the crank position sensor and cam position sensor before it fires. If it doesn't see them - no fire. Could be a bad sensor.
CATCRD is offline
post #5 of 15 Old 09-19-2009, 01:41 PM Thread Starter
inpursole
2005 KJ Liberty
replaced cam sensor, checked resistance of wires, 5volt ref, ground,and signal wires are good, checked my powers and grounds at ECU and no problems found
post #6 of 15 Old 09-19-2009, 01:42 PM Thread Starter
inpursole
2005 KJ Liberty
crank sensor reads fine on scanner
post #7 of 15 Old 09-19-2009, 04:59 PM
merlinTec
merlinTec's Avatar
does your scanner read fuel pressure? if it's not getting over 1000 psi the ecu will not pulse the injectors.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #8 of 15 Old 10-17-2009, 02:20 PM
libertybratt
I have the same problem with my 02 liberty
I have no fuel pressure and it will not start
the starter turns the motor fast though
is there something I can do
Is the check engine light supposed to come on for a moment with key on before you start the motor?
the cel never comes on at all right now though
libertybratt is offline
post #9 of 15 Old 11-13-2013, 10:09 AM
shawn1819
i have a 2005 crd diesel and she has no power and blowing black smoke put her on code reader and a lot of codes came up that dont make scene anyone have this problem before
that can help
shawn1819 is offline
post #10 of 15 Old 01-06-2014, 09:22 AM
Giffie
2003 KJ Liberty
i have a 2003 crd swapped motor to 05 not the ecu but not starting any help on this. The ecu is stil of the 03 just extended the crank sensors wiris not getting signal to injectors
Giffie is offline
post #11 of 15 Old 01-08-2014, 03:47 AM
Billwill
2002 KJ Liberty
How can you use a 2003 ECU on a 2005 engine?
There are major differences including the fact that the 2003 has a fixed vane Turbo and the 2005 has a variable vane turbo, 2003 has 12 volt glow plugs and no control from ECU while the 2005 has 7 volt (standard) glow plugs with a seperate glow plug controller.
2003 CRD , Export obviously, use a PCI bus for communications while 2005 uses a CAN bus mainly with only some PCI usage.
2003 CRD has the Alternator charge rate monitored and set by the ECU...2005/6/7 alternator has a built-in regulator.
The EGR is worked differently, 2003 does not have a Flow Control Valve, 2005 has an airflow sensor on the air intake.
Fuel delivery rates will be different etc.
Yes the engine in theory may start and run badly but there are so many sensors around on this engine doing various checks that I would only consider putting a 2005 CRD engine into a 2003 chassis if I could replace the ECU, TCM (if fitted) and complete wiring harness at the same time.
I think I have just answered your question for you
All of you guys having problems here on this post with your CRDs...I would suggest you go to the "CRD Liberty Love the Torque" section at:
http://www.lostjeeps.com/forum
All the experts are there!
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #12 of 15 Old 01-08-2014, 03:50 AM
Billwill
2002 KJ Liberty
Also the most common problem with the CRD engine turning over but not starting is air in the fuel at the filter head.
Also try swap over the ASD relay with an identical one next to it or jumper pins 30 and 87 together inside the ASD Relay socket and see what happens.
Billwill is offline
post #13 of 15 Old 01-08-2014, 03:55 AM
Billwill
2002 KJ Liberty
that can help
Holy dead thread resurection Batman!
If you are still having this problem then it is probably your CAC rubber hoses going to the Intercooler and back that have splits in them.
Best to replace with SAMCO Silicone hoses.
Billwill is offline
post #14 of 15 Old 03-17-2014, 04:10 PM
Giffie
2003 KJ Liberty
HI Billwill please contact me with your experts as i'm stuck with this problem0837851559
Giffie is offline
post #15 of 15 Old 03-19-2014, 02:01 AM
Billwill
2002 KJ Liberty
Sorry Giffie, I make no claim to be an expert....that is why I recommended that you go to the "Liberty CRD Love The Torque" section at:
If they cannot help you then you may as well give up!
Billwill is offline
06 liberty CRD wont start oscartango KJ Liberty Forum 18 01-17-2011 05:43 PM
03 Liberty will crank, but not start. Gray621 KJ Liberty Forum 3 11-18-2009 10:38 AM
03 Liberty No start bob55 KJ Liberty Forum 3 08-22-2009 10:52 PM
Where to start 04 Liberty renegade mradDiction KJ Liberty Forum 5 06-01-2009 11:22 PM
Why oh why does My '04 Liberty not start??? NJinTX KJ Liberty Forum 8 01-25-2005 11:52 AM
