How to reliably source a replacement engine? - JeepForum.com
post #1 of 5 Old 05-11-2013, 08:36 PM Thread Starter
LibertyDriver
My engine is beyond repair. I took it to the dealership and they have a list of 7 things wrong with it. I have found a reliable mechanic who can put in a new engine. This is my only option as I can't afford a new vehicle and I need this one to get me through another couple of years. It's a 2003 Liberty Limited.
I don't know where to start. Do I let this mechanic find an engine for me or do I get a reconditioned one online? I've looked and found a company called PowerSource. They have so many websites that any google search seems to lead to them.
Does anyone have any experience with them, any experience sourcing a new engine or any recommendations? Also, if I let the mechanic find an engine I've read that I can get a Carfax history report on it. Is that correct?
Any input would be much appreciated.
LibertyDriver is offline
post #2 of 5 Old 05-11-2013, 08:56 PM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Use the Car-Part.com website to search for a 3.7 liter from any Chrysler product from 2002 through 2011. You'll need to make a couple of mods if you use an engine from 2005 or later but the block itself is the same. The cost is much less than a reman - especially if you get an engine from a vehicle OTHER than a Liberty - and you should be able to find one with fairly low miles.
Here is a thread that gives more detail. PM me if your mechanic has more questions.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #3 of 5 Old 05-11-2013, 11:41 PM Thread Starter
LibertyDriver
Thank you so much for your response. I need to clarify a few things. I'm going into this blind. So you're saying that these Chrysler engines are all the same? If not then what am I specifically looking for?
I'm looking to spend under $2000 on the engine. I need it here by Tuesday, I have to have my car up and running by Thursday. I want to get as low a mileage as possible. I did a search a messaged the first 10 or so asking how quickly they can get it to me. Beyond that how do I know who is reputable? I'm in a rush but I don't want to make a mistake.
Thank you again for your help. You're very much appreciated.
post #4 of 5 Old 05-11-2013, 11:43 PM Thread Starter
LibertyDriver
Just to add that my engine has 113,000 miles on it and my two major concerns are time and reliability. Thanks.
post #5 of 5 Old 05-12-2013, 06:23 PM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
The long block (block, cylinder heads, timing cover) are the same but the oil pan, intake manifold and exhaust manifolds are different depending on whether you get a Jeep Liberty engine or another Chrysler product. Read through the thread I linked to for the specifics of what you need to use from your existing engine in order for it to work in your Jeep.
Unless you find a Liberty engine from an '03 or '04 and can do a quick swap it is unlikely you can meet your timeline. Having it running by Thursday isn't impossible but it will take a LOT of work and will require that pretty much everything goes perfectly. Projects like this always have a bump in the road somewhere.
Bob
