How many miles on your Liberty? - JeepForum.com
post #1 of 114 Old 06-12-2011, 07:35 AM Thread Starter
Turbobearcat
2015 KL Cherokee
I would love to see how many of you are over 100k,150k and 200k and beyond.
Also state what repair work you had done since you owned it.
2005 Liberty Sport
129k
water pump at 118k
Turbobearcat is offline
post #2 of 114 Old 06-12-2011, 12:25 PM
Bain98xj
03 sport 4x4 3.7 with 92k miles on it. only major issue was the rear upper control arm and lower thermostat housing bolt being rusted and rounding off
Bain98xj is offline
post #3 of 114 Old 06-12-2011, 02:14 PM
04liberty4x4
2004 Liberty 4x4 Sport, Water pump at 90K, Brakes at 80K, 90,300 miles on the car
Gets daily driven 20 miles on highway to work.
04liberty4x4 is offline
post #4 of 114 Old 06-12-2011, 05:46 PM
Slithering_Joe
2005 Liberty Limited 4x4, purchased new
Currently 65,000 miles
New battery
Positive battery terminal replaced
Ball joints (under warranty/recall)
Nothing else.
4.0L TJ
Slithering_Joe is offline
post #5 of 114 Old 06-12-2011, 11:18 PM
jeepkj617
2008 WK
2002. KJ renegade 120,820 miles. So far its just eats brakes and gas. A few light bulbs and a radiator
"What do you mean it don't work? Just hit it with a bigger hammer!"
Thinking about buying a Cobra® 29-LTD 2-Way 40-Channel CB Radio. Anyone have install/antenna suggestions?
jeepkj617 is offline
post #6 of 114 Old 06-13-2011, 08:40 AM
dcxman
2006 KJ Liberty
2006 CRD 104k.
EGR
Head remove and resurface to fix coolant leak into #1 cylinder
GDE flash
06 Jeep Liberty crd- 245/70/16 tires, fumoto valve
03 Neon
96 Ram 1500, 5.2,
99 Harley Sportster
88 Ford 350 diesel dump truck
02 Northwing Maverick Legend weight shift trike
dcxman is offline
post #7 of 114 Old 06-13-2011, 09:53 AM
Jeepsman
2005 KJ Liberty
123k
Ball Joints replaced @ ~110k
New Battery @ ~115
2005 Jeep Liberty
2006 Jeep Wrangler X (SnowWhite's)
Jeepsman is offline
post #8 of 114 Old 06-13-2011, 12:11 PM
Joenavy85
2005 KJ Liberty
'05 KJ Sport 2WD, 84800 Miles, changed spark plugs at 36k and 72k, flushed all fluids at 75k. Replaced battery in 2009 because my ex-brother in-law didn't know the proper way to wire up a new stereo head unit.
Joenavy85 is offline
post #9 of 114 Old 06-13-2011, 12:34 PM
tommudd
2004 KJ Liberty
04 156000 and not one problem only replaced normal wear items, front brakes at almost 100,000, rears at 135,000
Been lifted over 130,000 miles
buddy has an 03 with 186,000 on it about the same no issues with major replacements
Maintenance is the key
04 KJ WITH JBA 4 INCH COILOVER LIFT
03 KJ WITH JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #10 of 114 Old 06-13-2011, 06:22 PM
dmblair
2005 3.7L with 135000 miles and only issue I've ever had with it was a locked up rear caliper. Other than that I haven't had one issue. Hasn't stopped on me once since mile 000001!!! Like tommudd said, Maintenance is the key, if you take care of something it will take care of you~
dmblair is offline
post #11 of 114 Old 06-13-2011, 09:29 PM
ghettosled
2003 3.7L sport with 114k miles.
transfer case and rear differential pinion gear seal leaked at about 10k miles (warranty repair, thought the pinion gear had to be replaced twice) replaced crank sensor, cam sensor, brakes only once, on the second set of tires, AC system is non-functioning, just replaced the spark plugs for the first time, all fluids replaced a while ago and need done again, split rubber line from charcoal canister, muffler seam split and i wrapped with ducting and pipe clamps as a temporary fix but is holding up well so i forgot about it until now, original battery split and some miscellaneous tail light bulbs.
nothing major so im a happy camper.
ghettosled is offline
post #12 of 114 Old 06-13-2011, 09:33 PM
tjkj2002
2002 KJ Liberty
Not including wear items(brakes,tires,fluids,and such) or items broken by my stupid actions offroad zero failures for my '02 KJ with 77,000 miles,yes low miles for 9 years old but it sat in storage for 2 years also while deployed.
tjkj2002 is offline
post #13 of 114 Old 06-13-2011, 09:50 PM
oilbuner
2006 KJ Liberty
06 CRD 87,000mi
When the pavement ends, you better have some ground clearance!
oilbuner is offline
post #14 of 114 Old 06-17-2011, 02:08 AM
Primeswine
2007 KJ Liberty
Just hit 95k in my 07 sport, only thing besides basics was just replaced the wheel hub cause the bearings where going, no recalls somehow
Primeswine is offline
post #15 of 114 Old 06-17-2011, 09:03 AM
GPrime2
175k on mine, but it threw a rod and destroyed the engine. Too bad these engines are so expensive to replace.
GPrime2 is offline
Who has the most miles on their Liberty? Jeepsman KJ Liberty Forum 15 05-31-2013 05:19 AM
Wondering how reliable a 2007 Liberty is w/30k miles. Looking to buy one. all_bran KJ Liberty Forum 16 04-01-2010 08:57 PM
Not sure about buying '04 Liberty with 90K miles Brazuca KJ Liberty Forum 9 10-26-2009 02:36 PM
09 Liberty ticking at idle. Only 200 miles on it. 4.0Mike KJ Liberty Forum 7 06-16-2009 08:58 PM
Who has the most Miles on thier Liberty? Komzo's Ride KJ Liberty Forum 2 04-28-2002 12:55 PM
