How many miles can you get out of a tank of gas? - Page 5 - JeepForum.com
post #61 of 107 Old 05-27-2011, 12:46 PM
01CHEEKEE
Fresh plugs, auto plats, home from ocean city (169.9 mi), gOT 22.25 mpg...and that's driving 80, filled w/ luggage and two bikes hanging out back... Very happy! ESP considering before the plug change we were gettin horrible mileage
01CHEEKEE is offline
post #62 of 107 Old 05-27-2011, 01:12 PM
LibertyOrDeath
2005 KJ Liberty
How many miles on your KJ?
I argued with my wife about this (bad idea) but, if you fill up at different stations where the pumps cut off at different tank fullness levels, this whole MPG thing based on 1 fillup is pretty inaccurate, it really needs to be spread over more miles/fillups or, that you fill back up using the EXACT SAME pump at the same station and, getting really nerdy, ideally in the same temperature or close to it. If you start off on a truly FULL tank, drive 200 miles, fill it up at a station where the pump cuts off lets say, 1 gallon or even 1/2 short of how much was in there before, it will have big impact on your perceived MPG.
If you really used 10 gal to go 200 miles but that other gas pump stopped after putting only 9.5 gal back in, you think you went 200 on 9.5 = 21.05MPG, when in fact you used 10 gal and you got only 20 MPG.
And tire air pressure if it changed or driving on hot versus cold road conditions, other traction issues.
Lots of myths about fuel buying, buy it when its morning and cold, don't put the pump on high, all debunked but one tip is good - a good healthy gas cap will save you money in fuel loss, letting the tank breathe while trapping gas vapor = money.
Ok so I'm bored at work I admit it.
LibertyOrDeath is offline
post #63 of 107 Old 05-29-2011, 01:32 PM
paparod
2006 CRD, with 35 000 miles on it and I get a 16,5 MPG in city driving. I just had maintenance (fluids + filters changed) and the car is pretty much to stock standard, i.e. no lifts etc.
Going highway it increases to a rough 27 MPG...Almost a 50% difference and I must admit I am bit surprised by the low mileage in citydriving...
paparod is offline
post #64 of 107 Old 05-29-2011, 11:37 PM
01CHEEKEE
Wow yeah that's really low for crd...our gas gets nearly that, and some get that and better...
post #65 of 107 Old 05-30-2011, 01:08 PM
paparod
We'll that's my gripe. I really like the car, but mileage sucks.
Anyone with expercience in using engine-tuning from e.g. Green Diesel Engineering?
paparod is offline
post #66 of 107 Old 05-30-2011, 03:55 PM
95BadBoy
I was like one of the first few in the country to use GDE's tune. Had it loaded two days after picking up the little tractor, while driving it back from NH. Very knowledgeable folks when it comes to these VM diesels. They were actually in on the original software if I recall for these B4 DC decided all they wanted it to do was start - period.
Did wonders for the highway mpg's when driving it in the sweet spot @ about 1800 rpm. Big increase in felt torque, smoother throttle tip in, eliminates the potential for any EGR failures , quite a few other little tweaks. Went from 26 to mid 30's on highway mpgs. Had 1800 miles to really test the before and after effects. Very good stuff. Never really check city mileage, way too many things affect those numbers.
If I keep adding things to this rig - pretty sure I can get it back down to the original fuel econ though.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #67 of 107 Old 05-30-2011, 04:05 PM
dcxman
2006 KJ Liberty
With GDE you can expect about a 15% improvement in mileage not to mention the increased torque. An 05 will do even better.
06 Jeep Liberty crd- 245/70/16 tires, fumoto valve
03 Neon
96 Ram 1500, 5.2,
99 Harley Sportster
88 Ford 350 diesel dump truck
02 Northwing Maverick Legend weight shift trike
dcxman is offline
post #68 of 107 Old 05-30-2011, 06:42 PM
Libbyowner
I use Bosch Platinum+4/Spark Plug, which you can get it from autozone for 5.99 a piece. My libby is a 2003, so I believe it has a 17.5 tank in it. I am not sure what you mean by mileage, but it has just over 202,000 miles on it, and I am getting about 350/tank. (80% highway and 20% city)
Libbyowner is offline
post #69 of 107 Old 08-29-2011, 03:38 PM
All3Sports
2004 KJ Liberty
Last tank I got 280 and I'm at 100 with half a tank left, hope its not my driving, insurance is a %&@^ already when you're 17..
02 KJ Renegade - Totaled....
04 KJ Limited - OME 927/948 General Grabber AT2 247/75/16
All3Sports is offline
post #70 of 107 Old 08-29-2011, 06:26 PM
streetglideok
2005 KJ Liberty
46k miles on my '05 KJ 6speed, champion copper plugs in it with only 1k on them. I have 350 miles on this tank, and Im down just below the 1/4 mark now. Running midgrade gas, as it seems to run alot better with it, but granted, here in the mile high state, we have 85, 87 and 91 octane.
streetglideok is offline
post #71 of 107 Old 09-07-2011, 05:09 AM
Drewskii37
2005 KJ Liberty
I just got a 2005 Liberty and at first was worried about the MPG's since I traded in an 04 Mazda 6S but so far so good! i'm at about 250 miles on my first tank of gas and still just over 1/4 tank left! This Liberty has a 2 Gallon bigger tank so honestly i'm not too worried about it now since i'm seeing that like most people I feel confident I can get 300+ miles per tank which I barely got with my mazda in town. Maybe because i'm not such a lead foot with this suv! lol
Drewskii37 is offline
post #72 of 107 Old 09-07-2011, 12:20 PM
Boomerang
2006 KJ Liberty
I have an '06 Limited 3.7L 40k miles
I changed what appeared to be the original plugs at 38.5k, gapped at .035
Had new oil from the dealer. I was getting about 15-16 MPG
I changed the plugs (.040 gap correction) then changed them again at about 40k after using Seafoam in the oil, gas and vaccum lines. The treatment did not foul my plugs, but i put in new ones anyways (the plugs I had put 1k on still looked new, no carbon, ect..
Afterwards I put in an Amsoil air filter and synthetic 5W-30 plus their brand nam oil filter. Mileage so far has risen to about 17.5 and this includes mostly highway.
The oil/oil filter I put in says its good for 25k, but only if you use premium gasoline, cannot get the claimed 25k with the recommended gas for the Liberty.
I'm hoping that once the oil has worked in really well the mileage will go up. The seafoam treatment truly did wonders for my Jeep. It has brought back lost horses and is massively more responsive. Much smaller increases in the throttle have given much bigger responses, and I mean much bigger.
Consider this an experiment, I'll let you know if I gain further MPG.
When you know, you know. You know?
Boomerang is offline
post #73 of 107 Old 09-07-2011, 12:55 PM
streetglideok
2005 KJ Liberty
Last tank was 362 miles, and took 19.5 gallons to fill the tank. That included going over a 13k foot pass and crawling for hours in 4low. Curious about amsoil wanting the use of premium fuel though for 25k mile oil changes. That can lead to more problems.
post #74 of 107 Old 09-07-2011, 06:27 PM
tjkj2002
2002 KJ Liberty
Last fillup..........
112 miles(corrected) and 12.4 gallons to refill,loved every minute of it as 3 gallons was used over 7 miles in 4low going a average of 1.6mph.
tjkj2002 is offline
post #75 of 107 Old 09-08-2011, 06:50 AM
Ridin' Around
Just curious where this recommendation came from? In all of the training & literature I have, they simply ask that you use the fuel type recommended by the OEM.
Ridin' Around is offline
how many miles to you get per tank? clavoie KJ Liberty Forum 13 08-25-2010 02:49 PM
How many miles are you getting per tank? 08-09 KK JFD140 KJ Liberty Forum 38 08-26-2009 07:27 PM
How many miles on your CRD? Tough Guy KJ Liberty Forum 20 03-14-2006 07:45 PM
Just drove 600 miles on one tank/CRD Blue79 KJ Liberty Forum 10 10-09-2005 09:37 PM
First 500 Miles SpiffBoy KJ Liberty Forum 7 06-25-2004 12:56 AM
