How to install airbag impact sensor - JeepForum.com
post #1 of 3 Old 02-08-2010, 06:41 PM Thread Starter
d_jesky
2006 KJ Liberty
Hey guys I have a 2006 Jeep Liberty Limited with a bag airbag sensor and wiring. I have the new sensor and wiring but am afraid to install this because I don't want the airbag to go off or not work if needed. Does anybody have an opinion on this or know how to install it?
d_jesky is offline
post #2 of 3 Old 02-08-2010, 08:19 PM
tjkj2002
2002 KJ Liberty
Remove the airbag fuse(SRS fuse) and then disconnect the battery.After that turn on your headlights,they will not turn on but will zap all the stored energy left in the system,let site for about 30mins then swap the sensor.Then hook up the battery and re-install the fuse and go about your way.
tjkj2002 is offline
post #3 of 3 Old 02-08-2010, 09:49 PM
all_clear
Agreed with the above. When i changed out mine i didnt wait 30 mins, more like 5 is enough but depends on how safe you feel you need to be. Also by disconnecting the battery and turning the key forward for a min you discharge the system or turn the lights on as stated.
If your airbag light stays on there is something wrong with the system. At that point best to have someone test it for you. Most body shops that do collision work can do this.
2004 Jeep Wrangler, Auto Trans, LEDs throughout, 3" Lift, 35" MTZ's
Check out my official RE-build thread. Her name is Ilene
all_clear is offline
p0161 O2 Sensor Heater Circuit (Bank 2 Sensor 2) DaniLaurette KJ Liberty Forum 1 01-19-2009 04:04 PM
Airbag system differences Fouros KJ Liberty Forum 0 02-12-2008 08:07 AM
Passenger Airbag - Help RodG KJ Liberty Forum 5 02-11-2008 04:18 PM
05 Passenger Airbag BradF KJ Liberty Forum 7 05-26-2005 10:25 PM
Airbag light on Renegade04 KJ Liberty Forum 5 03-09-2004 04:23 PM
