How do you remove the tail lights? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > How do you remove the tail lights?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 02-20-2009, 04:07 PM   #1
Wrangler98
2006 KJ Liberty
I'm trying to get the tail light housings off my 06 liberty. I only see 2 screws per side but neither light will come off with them removed. I'm afraid to just pull on them for fear I have missed something.
2006 Jeep Liberty 65th-3.7/AT
1993 F-250HD SC 4X4-7.3/5spd ATS Turbo
1986 F-250HD 4X4-6.9/T19
1967 Ford Mustang-351W/4spd
Wrangler98 is offline   Reply With Quote
Unread 02-20-2009, 04:45 PM   #2
XR
2002 KJ Liberty
Remove the screws and pull straight out.There are two posts that go into grommets on the side opposite the mounting screws.Just pull it'll come off.And here's a tip lube the posts up with some dielectric grease before ya put 'em back they'll come out easier next time.
If it ain't broke'fix it 'til it is
XR is offline   Reply With Quote
Unread 02-20-2009, 06:49 PM   #3
Wrangler98
2006 KJ Liberty
Great, thanks. I figured it was safer to ask before I started pulling on things.
Unread 02-21-2009, 10:31 AM   #4
04KJlimited
2004 KJ Liberty
just yank it, i used an abs plastic door panel tool to pry the quarter panel side out, after putting blue masking tape on the paint. sometimes they can be a real pain in the @$$
04KJlimited is offline   Reply With Quote
Unread 02-25-2009, 04:54 PM   #5
hithere2ya
2006 KJ Liberty
re: Liberty tail lamps
Be careful when removing and reinstalling. There is a clear plastic separator piece inside that lays flat which, if it falls on top of the tail lamp due to shaking of the lamp assembly will cause a bulb failure within a few days. Then you will have to either break apart the plastic part r replace the entire assembly. Been there did that got a new tail lamp free because the dealer did it first time. I knew NOT to shake it up when it was time to replace a bulb out of warranty.
hithere2ya is offline   Reply With Quote
Unread 02-19-2011, 10:26 AM   #6
01CHEEKEE
2004 KJ Liberty
Bump for a good/helpful thread...installed a hitch and harness, ran into this problem!
01CHEEKEE is offline   Reply With Quote
