High End Power with 3.7 - JeepForum.com
post #1 of 10 Old 01-28-2013, 02:41 PM Thread Starter
PoundHipster
2005 KJ Liberty
Hey All-
I have a 2005 KJ 3.7L and was wonder what kind of power I should be expecting to have at high speeds and on inclines. I live in the foothills and do a lot of driving in the Rocky Mountains and have been pretty disappointed with the power I am getting at high speeds and especially while going up hills and mountains. Seems like I have barely any power.
Before this Fall I had a 2000 XJ 4.0L and I never felt like I was underpowered, but I lived in upstate NY and the Adirondacks are hardly the Rocky Mountains.
Stat sheets tell me my 3.7 has more power and torque than the 4.0, but I am not really feeling it. Should I look to replace spark plugs, etc, or is this just the difference between the Cherokee and the Liberty?
Thanks in advance!
Geo
PoundHipster is offline
post #2 of 10 Old 01-28-2013, 06:14 PM
tommudd
2004 KJ Liberty
When was the last tuneup? If its been 30,000 miles or so then yes throw some good copper core plugs in, it may help
Also make sure all maintenance is up to date
What type and size tires/ tire pressure etc makes a difference
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #3 of 10 Old 01-28-2013, 06:27 PM
kirksjeep
I too just switched my DD from and XJ to a KJ. I agree that the KJ doesn't feel like it has the same get up and go as the XJ, but I think it has more to do with the computer controlled transmission then anything else. Try driving it hard for a few days and the engine will wake up.
1992 YJ Sahara- 4.5" RE XD, 1" BL, 1" MML, 35" BFG MT, 8.8 w/Aussie, D30 w/Ten Factory shafts/ Aussie, 4:10 gears, Soild Diff Covers, SYE, CV Drive shaft, OBA, Flowmaster Super 44,, Custom head pipe, Super Chip, Boared out TB, Rock It Intake , Goferit Tie Rod Flip, 99+ intake manifold/Steering pump, custom front/rear bumpers,Hand Throttle, Hurst Shifter, Smitty Built sliders , 6" TJ flairs, Kilby belly up skid, Quadratech 9K winch, ZJ PS cooler. 01 XJ Sport-2" lift, 31x10.50 MT/ 02 Liberty 2" Lift
kirksjeep is offline
post #4 of 10 Old 01-28-2013, 07:37 PM
olliehopnoodle
1982 FSJ Cherokee
It does seem to lack the torquey feel and when you get on it the transmission jumps you up to a higher RPM but I think this was by design. It 'sounds' like it is strugglinng but in actuality it is doing okay. Certainly not a major power house of an engine though.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #5 of 10 Old 01-28-2013, 08:58 PM Thread Starter
PoundHipster
2005 KJ Liberty
Tommudd - I just got her in October, so I am not sure of what maintenance has been done, but I am coming up on the 90k service interval so I figured spark plugs should be replaced (should I definitely replace anything else?). It has 235/70s on it right now, but the spare is 225/75 so I figure it came with 225/75 from the factory. Would this make a difference? I keep the psi at the recommended level (tires are Dynapro ATM/ my xj had Destination A/Ts).
kirksjeep - I usually drive it pretty spiritedly, so I would think the computer would have adapted?
olliehopnoodle - I think the trans jumping is different from the XJ because of the O/D in the KJ. But even when it jumps back into 4 it pretty much plateaus with power.
I think my next step is going to be spark plugs, thanks for the input!
post #6 of 10 Old 01-28-2013, 09:37 PM
BobFromCO
2006 KJ Liberty
FWIW, 235/70 16's are actually the OEM size, so I think the spare is the odd man out.
BobFromCO is offline
post #7 of 10 Old 01-29-2013, 09:51 AM
DaveJKJ
2005 KJ Liberty
Originally Posted by PoundHipster View Post
Hey All-
Thanks in advance!
Geo
I live in the Adirondack area and have no problem but I do have to lock out o/d at times depending. I do have bigger tires though and no re-gear so that makes a difference. I have also driven in the Rockies and they are way bigger as you say but maybe it is also the altitude there and the lower octaine gas they sell if I recall right?
Otherwise for more power and a Jeep, you need a Hemi GC. I have driven one and they have plenty of power.
Change the plugs and use the OEM, NGK copper core ones and see if it makes a difference. Even if it doesn't they are only $18 or so at NAPA and can't hurt anything.
Lifted, Skids, Hooks, Rails, Trail Rash..
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline
post #8 of 10 Old 01-29-2013, 09:44 PM Thread Starter
PoundHipster
2005 KJ Liberty
I wonder if altitude has anything to do with it, since it is significantly higher than NY (range from 5-11k feet). I do always run 87 instead of the apparently "ok" 85 octane.
A Hemi sounds great right now!
post #9 of 10 Old 01-30-2013, 10:26 AM
Chipppy
2002 KJ Liberty
My 02 with the 45rfe feels much better all over power wise than my 07 with the 42 tranny. The 02 also have a mechanical throttle I believe witch makes the jeep feel much peppier in my opinion. If you don't mind the gas use overdrive up the hills would feel like it has more power since in a different rpm.
Chipppy is offline
post #10 of 10 Old 01-31-2013, 01:33 AM
PanosKJ
2005 KJ Liberty
...and if the O/D won't help then wait for foursevenKJ's write ups about 3.7 engine swap to GC 4.7 and follow them....I recon is the only solution if you need more power....besides 3.7 consumes a lot of fuel anyway so the swap won't make any difference on consumption level and at the same time, you'll get lots of great power (V8 plus a great transmission set up)......
My KJ is also 05 with 42 transmission so it needs lots of pushing and I'll do the swap no matter what....
PanosKJ is offline
