High Beams not working - JeepForum.com
post #1 of 2 Old 10-18-2010, 01:04 AM Thread Starter
stanggt84
Hello, I have a somewhat odd issue with a 02 KJ. When I go to turn on the high beams they turn on at the "flash to pass" position but go out when you fully turn them on and release the lever. I can hear the relay activating when they turn on. I have replaced the relay, bulbs, and the multifunction switch. I also checked all of the fuses with an ohm meter. I am at a bit of a loss as to what could be the problem from here. I have checked connections and don't find anything damaged or loose. I haven't seen any other odd behaviors with the electrical system.
Is it possible that this one circuit in the BCM has failed?
Is there any way to get a code from the BCM or to reset it?
Any thoughts or suggestions would be greatly appreciated. Thanks.
stanggt84 is offline
post #2 of 2 Old 10-19-2010, 11:01 PM Thread Starter
stanggt84
Has anyone seen this before?
fog lights and high beams mkm61689 KJ Liberty Forum 3 12-19-2008 07:51 PM
headlight problem, no low beams orangez KJ Liberty Forum 12 11-15-2007 12:20 AM
Air conditioner not working PVCS KJ Liberty Forum 15 07-20-2006 07:04 AM
fog lights with high beams?? joostin420 KJ Liberty Forum 6 03-16-2006 04:59 AM
Anyone know how the hi-beams work on the Liberty? BoeserBlick KJ Liberty Forum 2 04-08-2003 11:51 AM
