Quantcast HID Problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > HID Problem
Official Chassis Saver Rust Preventive Truck & Auto UnIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineTJ 5.25" Speaker Adapters - NalinMFG
Old 11-17-2009, 06:21 PM   #1
Carmodifier
2006 KJ Liberty
HID Problem
So I bought a 12000K (Exotic Violet) Bi-Xenon HID Kit for my '06 Liberty from eBay: HID CONVERSION KIT H4 9003 H13 9004 9007 Hi/Lo Bi-XENON:eBay Motors (item 170405021217 end time Dec-09-09 12:57:13 PST).
I installed the HIDs, but only the low beams work. When I turn on my high beams, my lights cut out on both sides. It does this when the engine is both on and off. I e-mailed the seller informing him of the problem. This was his reply: "On some vehicles with canbus, it will cause the lights to flicker because the car sense a drop in current and wattage consumption. You can try hooking up the ballast directly to the battery make sure you hook up red to (+) and Black to (-) if it works then you will need to get canceller."
Does the '06 Liberty have canbus? What do you think could be causing the high beams not to work? My only thought for why the high beams do not work is because he gave me a single beam HID kit, not a bi-xenon/dual beam kit. Thanks in advance for the help!
Carmodifier is offline   Reply With Quote
Old 11-19-2009, 05:11 PM   #2
Onlyina
2009 KK Liberty
It appears that your seller did not understand you problem.On single bulb headlamps like the Liberty's you need at least a Hi/Lo bulb.There are basically 3 bulb types in HID lighting.The single bulb that is Lo beam only would fit a vehicle that has a seperate bulb for the Hi beam.The Xenon/Halogen bulb that would be suitable for the Liberty with the Xenon Lo power coming through a ballast and the Halogen Hi power coming from your regular headlamp wiring.The Bi Xenon bulb get power from a ballast and is Xenon on HI and Lo with a shutter device built into the bulb that alters the Hi/Lo angle.If you had no problem with the Lo beams working then you only need a different bulb that has the Hi beam.You probably do not have Can-bus on the '06.You may need a relay harness.Hope this helps,I am trying to resolve a problem on an '09 Liberty.A different eBay seller sent me the Hi/Lo kit,then the relay harness and now I'm waiting for a Capacitor kit all to solve a flickering problem.Good Luck
Onlyina is offline   Reply With Quote
Old 11-19-2009, 07:33 PM   #3
infernicus
2007 KJ Liberty
The 9007 bulbs that are used in the liberty have two filaments producing light.. HID's work differently, so you will not have a high beam, usually the bulbs are bright enough anyway.. but you lose the 'flash to pass' feature.. If you wish to have a "high" beam, your best bet would be to get the HID kits with the halogen bulb, so you can pass inspection. they don't really produce any light. The kits that actually move the bulb back and forth are a pain to install (you have to hook them up to a power source and run extra wires, not too hard, just annoying.
check these out, they are for 9004(which is similar to our 9007 bulbs, but do not work for us, you would have to get the 9007)
HID Xenon HID + Halogen Dual Beam Kit H4-2 9004-2:eBay Motors (item 170403730255 end time Dec-06-09 11:26:46 PST)
Read that page, tells you about the bulb, and shows pictures..
I hope I didn't confuse you even more, lol.
-Dean
infernicus is offline   Reply With Quote
Old 11-20-2009, 03:59 PM   #4
almikyska
DO you know if the just halogen bulb on the HID kit is replaceable?
-Alex
almikyska is offline   Reply With Quote
Old 11-20-2009, 05:07 PM   #5
Onlyina
2009 KK Liberty
-Alex
Probably not.Thats a good question because although the halogen buld is for Hi beam only a not used as much as the Xenon low,when it burns out the whole bulb assy.would need to be replaced.
Old 11-20-2009, 07:28 PM   #6
almikyska
Well i just purchased that HID kit so when it comes ill see what can be done and ill be sure to let you know.
Old 11-21-2009, 01:30 AM   #7
infernicus
2007 KJ Liberty
You most definitely can buy just the bulb.. the HID "kits" are made up of a 'ballast' (which converts the power source, into a different output than the stock bulb, since HID's use Xenon gas, and not Filaments in traditional bulbs) and a bulb which usually attaches to the ballast with two wires. If you just recently bought the kit, I would just try to return it and get the correct kit. Unless your bulb burnt out, then I thnk you can just replace the bulb. would be cheaper anyway.
Old 11-21-2009, 06:34 PM   #8
Onlyina
2009 KK Liberty
Please let me know where you can buy just the Halogen part of the bulb,I would like to keep a couple on hand.
Old 11-22-2009, 02:58 PM   #9
Carmodifier
2006 KJ Liberty
-Dean
First of all, thanks guys for all the input!
So, are you saying that you cannot get a single HID bulb that will do BOTH low-beam and high-beam? It sounds like you are saying that you can only have high-beams with halogen bulbs, not HID bulbs. Am I understanding this correctly?
Old 11-22-2009, 05:48 PM   #10
Onlyina
2009 KK Liberty
The BiXenon is HID Xenon hi and Lo.The HID hi/lo is Xenon lo and Halogen hi.
Old 11-23-2009, 07:40 PM   #11
almikyska
I havent found out what bulb type the high beam is yet but if i do ill let you know. and i have to say DO NOT LOOK DIRECTLY AT THE HID WHEN ITS ON its friggen bright learn from my mistake
Old 11-24-2009, 03:04 AM   #12
Carmodifier
2006 KJ Liberty
Since I bought a Bi-Xenon HID Conversion Kit I should have Xenon hi and lo. I did a basic HID hook-up: swapped the halogen bulbs out with the HID bulbs, connected the ballasts to the HIDs, etc. Is there some "special" way I need to install this kit to make the hi-beams work?
Old 11-24-2009, 05:08 PM   #13
Onlyina
2009 KK Liberty
Are you sure you have Bi-Xenon bulbs? Beside the ballasts and bulbs you should also have a controller that gets wired to the original headlamp connector and controls the hi/lo movement of the Bi-Xenon bulb.On your original post you had a link to the seller,the photo shows a Bi-Xenon bulb in the middle of 2 regular single beam Xenon bulbs.There is also a wiring diagram that shows a picture of a Hi/Lo controller.If you got everything you paid for there is no reason it should not work.You should contact the seller.Good luck.
Glock Forum
