Hi-Lift - JeepForum.com
post #1 of 4 Old 06-02-2013, 10:46 PM Thread Starter
kaleo333
Hi-Lift
So I was messing around with my factory jack today to make sure I knew how to change a tire... and I quickly realized I can't get the Jeep off the ground now, and I'm about to add even more lift... How do you guys recommend I get it up to change a tire or something? should I just be jacking from a different spot or is a Hi-lift the best way to go? And what size hi-lift will I be needing along with any useful accessories for the trail? And finally, how should I go about mounting this to the Jeep? Thanks for any help, I'm clueless...
kaleo333 is offline
post #2 of 4 Old 06-03-2013, 01:14 AM
jbarthol
2005 KJ Liberty
Believe the manual says to put it under the axle, on the side your lifting.
jbarthol is offline
post #3 of 4 Old 06-03-2013, 06:16 AM
tommudd
2004 KJ Liberty
Lifting under the axle will do it with stock jack
Unless you have steel bumpers or aftermarket rock rails a Hi-Lift will not do you much good since there would be no where to use it.
Some do use it in the hitch but to change a ire it wouldn't work too well. They do make a kit that you lift the wheel up, but kind of blundersome if again just changing a tire
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #4 of 4 Old 06-03-2013, 09:42 AM Thread Starter
kaleo333
Would the spot in the manual for changing a front tire still work? And rock rails are on the to do list... But not quite my next project
kaleo333 is offline
