[Help] Transmission problem - JeepForum.com
post #1 of 13 Old 03-22-2014, 07:53 AM Thread Starter
omega48er
i posted this over at JeepKJ.com and thought it would be a good idea to post it up here as well
Hi guys, so i just finished dealing with the Valve cover gasket replacement and i need help with yet another issue.
I have an 03 Jeep liberty with the 42rle transmission and when i come to a stop sign and try to accelerate the jeep does not move but you can hear it accelerate. i need to put the jeep in neutral then drive and its fine. it does not happen all the time, just like once a week or so.
some possible suggestions people have made is:
linkage slipped Or Trans control ECM has gone bad.
Thanks for any info.
2003 Jeep Liberty KJ -GONE
2006 Jeep Commander 5.7L HEMI
2009 CLK550- Garage Queen
omega48er is offline
post #2 of 13 Old 03-22-2014, 07:45 PM
Wonderskid
2004 KJ Liberty
In my limited understanding, I'm leaning towards the linkage. I've come across a few similar threads and it seems there is a common issue with the Liberty shift linkage needing adjustments.
Just my 2 cents.
Wonderskid is offline
post #3 of 13 Old 03-22-2014, 09:31 PM Thread Starter
omega48er
^thanks man. it should be an easy adjustment rite?
do i need to crawl up under the jeep and adjust some linkage there or should it be on the inside by the shifter?
if you can direct me towards any post that had a diy would be great.
thanks
post #4 of 13 Old 03-22-2014, 10:10 PM
olliehopnoodle
1982 FSJ Cherokee
I thought it was all solenoid activated? Next time it does this, try putting it in first instead of neutral
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #5 of 13 Old 03-23-2014, 09:51 AM Thread Starter
omega48er
^will do that. btw. what is that supposed to do or prove?
post #6 of 13 Old 03-23-2014, 05:36 PM Thread Starter
omega48er
alright, so its cold and im putting off getting under the jeep until its nice.
question: what exactly am i looking for? i found a few posts on the wrangler side and its the linkage going from the shifter to the transmission and its connected by some cheap plastic nipple that is prone to breaking. is that it?
post #7 of 13 Old 03-23-2014, 06:57 PM Thread Starter
omega48er
i did go in the jeep and pull the cover the shifter and everything looks good there, so once the weather gets better ill get under the jeep.
also, should i go ahead and drop the pan change the oil filter and gasket?
post #8 of 13 Old 03-24-2014, 12:59 PM Thread Starter
omega48er
any other advice would be appreciated.
thanks
post #9 of 13 Old 03-25-2014, 08:41 PM
olliehopnoodle
1982 FSJ Cherokee
If it is just an adjustment problem then putting into 3/2/1 will work as well as putting into neutral. At least that is my thinking.
post #10 of 13 Old 03-30-2014, 03:34 PM Thread Starter
omega48er
Thanks, i will do that, it has not happened 100 miles after i put in 1/2 quart or ATF+4 in it.
i am doing a whole drop pan service when the parts come in.
Thanks
post #11 of 13 Old 04-03-2014, 07:04 PM Thread Starter
omega48er
okay so the problem occurred again today, i put it in 2/1 and the problem continued. put it in neutral the Drive and its back to normal. i will be doing the Drop pan service
this or next weekend.
post #12 of 13 Old 04-06-2014, 03:23 PM Thread Starter
omega48er
So i replaced gasket, the filter, magnet and a new pan. And the good thing was there is no brads color shavings.
Took the jeep down the Avenue and it responded better.
Will keep you guys updated
post #13 of 13 Old 04-06-2014, 05:16 PM Thread Starter
omega48er
also, when i drained the transfer case the oil was black as night.
and the bolts on the transmission pan were loose, meaning when i put the socket on them i could twist them off with out applying any force.
