HELP....transmission?? - JeepForum.com
post #1 of 14 Old 03-30-2014, 03:22 PM Thread Starter
BeccaS
2004 KJ Liberty
I have a 2004 Liberty. All of a sudden, there is a weird noise, clunking like, as if it may stall, but it doesn't. Then, it goes into gear VERY hard. It does not want to shift at all. It will upshift with less problem than downshifting. (it's a 5spd)
BeccaS is offline
post #2 of 14 Old 03-30-2014, 06:43 PM
02blue
2002 KJ Liberty
Is this a manual or automatic transmission? Either way I'd check the fluid level first and go from there.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is offline
post #3 of 14 Old 03-30-2014, 06:54 PM Thread Starter
BeccaS
2004 KJ Liberty
It's a manual, 5spd. I know this sounds stupid, but is there an easier way to check the fluid than underneath? I don't see where there is a dip stick....
BeccaS is offline
post #4 of 14 Old 03-30-2014, 07:09 PM
02blue
2002 KJ Liberty
I don't have experience with the KJ manual but check out this thread:
http://www.jeepkj.com/forum/f196/04-...hifting-48414/
02blue is offline
post #5 of 14 Old 03-30-2014, 07:12 PM
02blue
2002 KJ Liberty
One more:
http://www.jeepkj.com/forum/f196/200...-change-52201/
02blue is offline
post #6 of 14 Old 03-30-2014, 08:54 PM Thread Starter
BeccaS
2004 KJ Liberty
Thanks so much. Waiting for the rain/snow to stop & will start by checking the fluids
BeccaS is offline
post #7 of 14 Old 03-30-2014, 09:00 PM
02blue
2002 KJ Liberty
Oh geez Eastport ME you are way up there! We actually had a nice blast of rain/sleet/snow here in northern MD. Weird winter/spring.
Good luck and keep us posted.
02blue is offline
post #8 of 14 Old 03-31-2014, 03:33 AM Thread Starter
BeccaS
2004 KJ Liberty
Yeah, it has been a rough winter. Hoping to be able to get under it today, but it's a big mud pit out there from the rain.
BeccaS is offline
post #9 of 14 Old 04-01-2014, 07:49 PM Thread Starter
BeccaS
2004 KJ Liberty
Well, now I am told it may be that my clutch needs to be adjusted. Have not been able to check the fluid yet due to weather, and, I can't even buy it I have to order it online. But, if it is a clutch adjustment....any clue as to where to start with that?? I have no idea. I hate to play the "I'm just a woman" thing...but......
BeccaS is offline
post #10 of 14 Old 04-01-2014, 08:01 PM
The_Dealer
2003 KJ Liberty
I'm not familiar with the kj 5spd, so I'm not sure about a clutch adjustment. Every manual trans rig I've ever had, showed those symptoms when the clutch or slave cylinder was going bad. You could try bleeding the slave cylinder and see if it helps. Also how does the pedal feel? Soft or firm?
Also is it easier to go from 1st to 3rd then from 1st to 2nd?
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #11 of 14 Old 04-01-2014, 08:54 PM Thread Starter
BeccaS
2004 KJ Liberty
Thank you. It feels the same as it always has...some tension...normal I think.
BeccaS is offline
post #12 of 14 Old 04-02-2014, 12:19 AM
The_Dealer
2003 KJ Liberty
Where does it disengage/engage in relation to the floor (pedal travel)? Does it start to engage/disengage close to the floor, or is it 1/2 travel or higher?
My build
post #13 of 14 Old 04-02-2014, 06:38 AM Thread Starter
BeccaS
2004 KJ Liberty
I would say maybe 1/4 of the way out, the vehicle will move (if that) My other car (Pontiac Vibe) You have to have the clutch right to the carpet to start it. Jeep isn't that way.
BeccaS is offline
post #14 of 14 Old 04-04-2014, 04:41 PM
USPLiberty
For a manual trans, it sounds like a worn clutch problem. Maybe an adjustment? Messed up clutch to pedal linkage?
USPLiberty is offline
