HELP! transfer case(?) noise! - JeepForum.com
post #1 of 5 Old 06-15-2012, 06:44 PM Thread Starter
jklanier84
2002 KJ Liberty
Guys I REALLY REALLY REALLY need some help here!
So after a good mudbath I noticed a really odd metal on metal noise. Its kind of a grinding/squeek. Its deffinatly a rotational noise, by that i mean it is a rythmic, repetitive noise happening every time something rotates, in the same way a wheel bearing has that "whuhh-whuhh-whuhh-whuhh" albeit a TOTALLY different sound.
Ive heard a differential blow out and my noise has a hint of commanality, like ya know that grinding noise that comes from all the broken bits in the diff rattling arround? yea, its like a little tiny version of that (like there is only one piece rattling arround) with a squeek added in for an extra scarry problem.
I DONT think its a wheelbearing because with the front end in the air i can spin the tires and cant duplicate any hint of the mystery noise.
then in desperation i yanked off the skid plates for a better look arround...
heres what i found where the front driveshaft comes out of the transfer case...
i sprayed INOX into the ripped seal and the noise has all but gone away...
I'm GUESSING that the seal was bad, then i drove it through the mud, muck, and water, and totally screwed my transfer case. Im HOPING i can drain the t-case fluid, replace that seal, then fill the t-case and problem solved...
jklanier84 is offline
post #2 of 5 Old 06-16-2012, 01:07 AM
tphitterlude92
You are only going to have to spend $65. That is the cv joint. Look up driveshaftparts.com then search for it in there sorry I don't have the link I'm on my phone. It's easy to change, I'm ordering one tomorrow morning.
tphitterlude92 is offline
post #3 of 5 Old 06-16-2012, 08:45 AM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Yep, the boot on the CV joint is bad (common issue) and so time to replace the CV joint.
As tphitterlude92 said, it's a $65 part. Easy repair to do yourself if you're a moderate garage mechanic. There's a great how-to with pics over at JeepKJ.com.
Here's a link to the part:
Jeep Liberty CV joint -Transfer Case end
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #4 of 5 Old 06-16-2012, 10:47 AM Thread Starter
jklanier84
2002 KJ Liberty
I love you guys right now! Lol. I was fearing a new t-case or driveshaft. $65 I can so live with. Plus it gives me an excuse to crawl under the jeeper and get dirty!
02 Ironman KJ
"When you have a Jeep, you must do Jeep things."
post #5 of 5 Old 06-18-2012, 07:13 AM
tommudd
2004 KJ Liberty
Yes once that boot goes then dirt etc gets in there and it basically destroys the bearings which rotate all of the time so yes it would be a rotational noise
Replacing the 2nd one in mine this week, but with 172,000 I guess I can't complain
04 KJ WITH JBA 4 INCH COILOVER LIFT
03 KJ WITH JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
Transfer Case ? MJT0902 KJ Liberty Forum 0 04-10-2011 11:39 PM
looks like i need a transfer case jamesdart KJ Liberty Forum 3 03-29-2010 08:00 PM
looks like i need a transfer case jamesdart KJ Liberty Forum 0 03-29-2010 07:43 PM
transfer case NV242 omani KJ Liberty Forum 4 02-01-2008 03:09 AM
Transfer Case cheese4420 KJ Liberty Forum 7 09-05-2007 04:18 AM
