Help me get this pain out of my a$$ - JeepForum.com
post #1 of 4 Old 07-01-2012, 02:39 PM Thread Starter
turbodsm96x
Just received my 3.7L Jeep Liberty back from the shop, complete engine overhaul. All was great first few days, then all of a sudden it started to bubble in the reservoir and overheat.
I went ahead and purged the system, added coolant. Vehicle was fine for another 2 days. Then the same **** happend.
Before overhaul vehicle was bubbling aswell. I heard weird sounds coming from the dashboard, could it be the heatercore?
Addltn info. New water pump, radiator, thermostat, reservoir cap.
No leaks. Just bubbling. It seems to me air enters from somewhere when driving.
I'm pointing toward heater core if fhats even possible. Just the cracklin sounds I get r not normal
turbodsm96x is offline
post #2 of 4 Old 07-01-2012, 06:10 PM
tjkj2002
2002 KJ Liberty
Take it back to who fixed it as it's not fixed as it's doing the same thing it was doing before the "fix".
tjkj2002 is offline
post #3 of 4 Old 07-01-2012, 07:53 PM
95BadBoy
Turbodsm96x - First Post - welcome to JF
Always a pretty good idea to not start off on the first post tripping the forum language sensor. Just saying.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #4 of 4 Old 07-01-2012, 10:45 PM
streetglideok
2005 KJ Liberty
Yep, take it back to the shop who did the work. If it did it before the work, then theres a good chance the problem wasn't corrected. I haven't been impressed with shops that do engine overhauls there, instead of replacing them with a reman unit. The work tends to be on the cheap, and corners cut, from my experience. Its one thing to do it for yourself, or a friend, as you are likely to take the time needed to have things checked, etc. Its another when they are just interested in turning and burning.
streetglideok is offline
2002 Liberty Oil filler a big pain in the @$#!! unclejack KJ Liberty Forum 3 10-09-2010 08:56 AM
Stock Lugnuts - A pain! LibertynJustice KJ Liberty Forum 5 10-17-2007 03:23 AM
