-   KJ Liberty Forum (http://www.jeepforum.com/forum/f28/)
-   -   help! Lower coolant hose leaking (http://www.jeepforum.com/forum/f28/help-lower-coolant-hose-leaking-1466726/)
antman630 01-20-2013 11:02 PM
I just replaced water pump, thermostat, and hoses because I had a leak an tire kingdom said that those were my issuses I got every thing to together flushed system an added new coolant got it to running temp with no leaks nowhere then I took it out for a test drive and now my lower hose by my thermostat houseing Seems to be leaking and I have coolant on fan blades what's going on!
Line58 01-20-2013 11:09 PM
The folks over on the KJ part of the forum would likely be better able to assist you.
That said, where exactly does the coolant appear to be seeping out of? Is the hose seated firmly? Clamped on?
antman630 01-21-2013 06:01 AM
Lower hose at thermostat hoseing, yes an yes I did have to cut each end of the hose about an 1/4inch on each end for it to fit with out to much bend in the
biffgnar 01-21-2013 08:07 AM
22 Attachment(s)
Are you sure its the hose? Sometimes thermostat housing doesn't get mated back to the engine well and leaks. Or thermostat housing cracks easily. How tight did you torque it when remounting?
antman630 01-21-2013 10:02 AM
Manufacture says 13 pound so I make it wrist tight on getting coolant on the hose and front of houseing and leaking on cross member I can't see ot coming out of the houseing is my fan getting wet cuz it running and it sucking coolant onto itself from where ever the leak is
Line58 01-21-2013 10:54 AM
This is for the 3.7 in your KJ Liberty, right? When talking about torque specs descending the engine will be important.
antman630 01-21-2013 04:12 PM
It's a 3.7 .. why is there coolant on my fan
antman630 01-31-2013 07:24 PM
It was my rad.
The time now is 04:57 PM.
