help! Liberty wont start! - JeepForum.com
post #1 of 10 Old 11-14-2008, 10:41 AM Thread Starter
rick2010
1987 YJ Wrangler
Buddy of mine has an 03 liberty and he went to start it this morning and it was dead. I went to jump start him and their is power, the jeep will start, but soon as it starts it dies immediately.
It has a full tank of gas
all the spark plugs are tight
no loose wires
don't really know what to look for......any ideas?
Any help appreciated.
rick2010 is offline
post #2 of 10 Old 11-14-2008, 10:53 AM
yellocoyote
2002 KJ Liberty
Maybe bad fuel filter or fuel pump? How long does it stay running after it is started?
yellocoyote is offline
post #3 of 10 Old 11-14-2008, 11:24 AM
Jakked
More description needed. You said there is power, but you had to jump-start him. What are the circumstances?
Is there power if you don't jump-start him?
Does the Jeep start and then shut off while the two vehicles are still connected to the jumper cables?
If it is a bad battery (or possibly alternator), it is not unheard of to jump-start the vehicle, and then have the vehicle die as soon as you disconnect the jumper cables.
2004 Liberty Sport 3.7L A/T 4x4 Cmd-Trc
Former 4x4s:
1999 TJ 4.0L I-6 4x4 5-Sp *Mods*
1986 Trooper 2.3L I-4 4x4 5-sp
Jakked is offline
post #4 of 10 Old 11-14-2008, 12:39 PM
jsc7002
1966 CJ5
is the battery dead? my battery went dead so I jump started it and it just died unless you kept giving it gas
jsc7002 is offline
post #5 of 10 Old 11-14-2008, 03:58 PM
DaveJKJ
2005 KJ Liberty
I think you need to test the battery. That would be the first and most likely thing to check. You said it is an 03 so is it the original battery? Some of the auto parts places will test them free if you don't have a tester yourself.
Lifted, Skids, Hooks, Rails, Trail Rash..
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline
post #6 of 10 Old 11-14-2008, 09:58 PM
ChvyKc
2006 XK Commander
I just posted this in another thread, just thought that I would throw it up here:
Same thing happened to my wife's car when the battery started to die. I pulled the codes with a scanner and came up with the same thing. I ended up replacing the front O2 sensor, IAC and a purge solenoid and it didn't fix it. Everything fixed itself when I replaced the battery.
I don't think that the actual problem was fixed but the car runs fine now. When I would start the car without the battery some of the gauges would flicker but I even had the alternator tested at two different places and it test perfect both times. Good luck figuring out what's wrong with yours. PM me if you need any help.
-ChvyKc
'06 XK 3.7L (Stock for now)
'07 WK HEMI Limited (Wife's)
ChvyKc is offline
post #7 of 10 Old 11-14-2008, 10:48 PM
jsc7002
1966 CJ5
the KJ's tend to do some crazy things when the battery dies
jsc7002 is offline
post #8 of 10 Old 11-17-2008, 12:15 PM
ATXKJ
2005 KJ Liberty
Odds are the battery - they have to have enough voltage to turn on the computer - engine running doesn't count if the computer's not on - the engine will die.
(low odds - but another forum someone had key problems - the computer will also turn off the engine if it doesn't recognize the key code)
ATXKJ is offline
post #9 of 10 Old 12-27-2008, 12:41 PM Thread Starter
rick2010
1987 YJ Wrangler
Battery replaced.....All is good now
rick2010 is offline
post #10 of 10 Old 12-27-2008, 03:40 PM
RMRSRT
2002 KJ Liberty
Whenever my battery drained and I jumped it with another car my jeep would turn over but immediately shut off. I would have to hold onto the gas for a good 10-15 minutes in order for it to stay idling. I guess if the battery is low on charge it would not have enough juice to keep the car running. After pressing on the gas for a while it would be fine. Weird, I know.
RMRSRT is offline
CRD Liberty has power wont start after running Projoman KJ Liberty Forum 26 01-15-2013 06:22 PM
06 liberty CRD wont start oscartango KJ Liberty Forum 18 01-17-2011 05:43 PM
Wont Start Tpeace KJ Liberty Forum 1 06-16-2009 08:53 PM
Jeep Liberty Ignition Key wont release aquaman2009 KJ Liberty Forum 1 05-16-2009 04:34 AM
04 Liberty Radio Wont Eject 04Jeepster KJ Liberty Forum 6 11-16-2007 07:35 PM
