Help! Jeep Liberty Instrument Panel Question - JeepForum.com
post #1 of 6 Old 12-30-2013, 02:57 PM Thread Starter
cactusdulce
Hello. I have a 2002 Jeep Liberty Limited, 118,000 miles and today it failed inspection because the airbag light does not come on at start-up. I have googled my fingers off and can only find issues with the airbag light staying on, not never coming on as in my case. To be honest, I have had the car for 4 years and have never noticed whether the light has ever been on or not at start-up. Its never failed inspection before. All other lights work fine, no other issues. Any suggestions before I head out to pay the $100 diagnostic fee? Could it be a burnt out lightbulb? All the lights around where the airbag light is all work fine. So confused. Thanks ub advance for any advise or suggestions!
PS, I'm a girl with limited experience, so please use laymen's terms LOL
cactusdulce is offline
post #2 of 6 Old 12-30-2013, 04:31 PM
tjkj2002
2002 KJ Liberty
No bulb,uses a LED which can be burnt out but better to be safe and get the diagnostic done.
tjkj2002 is offline
post #3 of 6 Old 12-31-2013, 01:49 AM
Billwill
2002 KJ Liberty
There is a good chance that the previous owner of your Jeep, or the Dealership, deliberately removed the LED from the Cluster to hide a constantly-ON Airbag light...instead of fixing the problem.
With ignition turned On the Airbag Light should come on for a few second and then turn OFF if the system is working.
You can also excercise all the cluster lights and the gauges by holding in the Odometer trip-reset button while turning the ignition ON....al the cluster lights....including the airbag light...should come ON and the gauges should move back and forth. If this does not happen then you need to remove the cluster, open it up and have a look at where the Airbag LED is located...probably has been pried off or it is burnt out. If this is the case you can get a replacement LED from Radio Shack and have someone solder it into place for you.
If the Airbag light is now ON permanently...you need to get codes read to see which airbag it is complaining about.
2002 2.5 Export CRD Manual 5 speed.
Billwill is online now
post #4 of 6 Old 12-31-2013, 12:07 PM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Billwill, you are an amazing source of information on anything electrical when it comes to the KJ. Really glad to have you around here!
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #5 of 6 Old 12-31-2013, 01:10 PM
samse2101
Bob
x2
samse2101 is offline
post #6 of 6 Old 12-31-2013, 11:28 PM
Billwill
2002 KJ Liberty
Originally Posted by samse2101 View Post
x2
Qualified in Electrical Engineering Light Current and 34 years in support, now retired!
Unfortunately I do not do house calls to the USA
airbag , problem , troubleshoot
