help with engine codes (8 of them) - JeepForum.com
post #1 of 12 Old 10-19-2010, 06:41 PM Thread Starter
sadik007
So many codes, where do I start, any ideas?
p0325 p0326 p0327 P0225 P0373 P1642 P0477
This is Jeep Libery 3.7L 2003 model. Car has about 80 000 miles on it.
sadik007 is offline
post #2 of 12 Old 10-19-2010, 08:37 PM
richd
2008 KK Liberty
First of all it would be nice to know what vehicle we are talking about,and miles,plus this is a readout you got for your vehicle?
richd is offline
post #3 of 12 Old 10-19-2010, 08:46 PM
rivalarrival
Stormaggedon
rivalarrival's Avatar
Clear them all and start over. Anything that pops up more than once, start looking at.
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine
We work together every damn day. --Jon Stewart
Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it.
Low Output 4 Cylinder Jeep Club member #188
rivalarrival is offline
post #4 of 12 Old 10-20-2010, 02:49 AM Thread Starter
sadik007
Hi, thanks for quick response.
This is Jeep Libery 3.7L 2003 model. Car has about 80 000 miles on it. These codes are after clearing then and then driving for a day.
sadik007 is offline
post #5 of 12 Old 10-20-2010, 03:25 AM
bradbb2005
2008 WK
Well, do you have symptoms first of all?
Is this something your are currently driving or is it sitting somewhere broken down?
How about a little background info. It's like walking up to a random doctor you dont know and saying "my leg hurts and its hard to breath".
Current:
2008 WK Limited 5.7L HEMI
Mods: | JK Moabs | 245/70-17 General Grabber AT2 | 1.25" Wheel Spacers
2008 KK 3.7L V6
Mods: | 225/65-16 General Grabber AT2 |
bradbb2005 is offline
post #6 of 12 Old 10-20-2010, 03:42 AM Thread Starter
sadik007
symptoms: rough ideal, almost stalls, misfire type engine vibration (spark plugs replaced)
sadik007 is offline
post #7 of 12 Old 10-20-2010, 05:55 PM
richd
2008 KK Liberty
I would start with checking your wiring harness.When you have this many multiple codes,in most case means a wiring harness problem,or bad connection.I have seen and read about multiple codes and it would be odd to have all those circuit go at once.It also could be a bad PCM.
richd is offline
post #8 of 12 Old 10-20-2010, 06:09 PM
tjkj2002
2002 KJ Liberty
Some of those codes do not even pertain to the KJ,a gas KJ at least as the 3.7 does not have a EGR.
I'd scan the codes with a better scanner to get the real codes.
Always start with the lowest # code 1st,amy resolve all the other codes in the process.
tjkj2002 is offline
post #9 of 12 Old 10-20-2010, 08:24 PM
richd
2008 KK Liberty
Tj- your right on some of those codes,but it looks like 08+ 3.7 have a egr valve;
Item NumberMSRPCore PricePrice53034192AA $77.80$0.00$56.45Emission system - Emission components - Egr valve - 3.7 liter
3.7 liter - 2008-10 2009 - 2010
richd is offline
post #10 of 12 Old 10-20-2010, 10:16 PM
tjkj2002
2002 KJ Liberty
His is a '03 so what ever computer program(not a scanner) he is using is not correctly setup to read a '03 KJ.Plus the fact it does not list OEM specific codes I wouldn't trust what ever it displays,heck my $30 code puller is CAN readable and has all the OEM specific codes in it.
tjkj2002 is offline
post #11 of 12 Old 10-20-2010, 10:23 PM
richd
2008 KK Liberty
My next question was going to be who and where did he get these codes.
richd is offline
post #12 of 12 Old 10-20-2010, 10:30 PM
tjkj2002
2002 KJ Liberty
I can tell you by his pic it's on a PC and it's a "Global OBDII" generic code reader program,just by the terms "Mode 3/7 and so on.
tjkj2002 is offline
More engine codes EZLiberty KJ Liberty Forum 4 08-09-2009 12:09 PM
Check engine codes???? sefroe KJ Liberty Forum 22 03-22-2009 06:48 PM
check engine light - codes vmckenny KJ Liberty Forum 0 04-03-2008 01:35 PM
Clearing Engine Codes... maascow KJ Liberty Forum 4 06-06-2006 07:53 PM
Check Engine Codes... Mitchb KJ Liberty Forum 13 12-03-2005 03:16 PM
