Help brake job!!! - JeepForum.com
post #1 of 9 Old 10-20-2005, 03:38 PM Thread Starter
arieljeep
Help brake job!!!
My frind has 2003 Liberty and he is getting a brake job done to his jeep, roters and pads on the back and front, and its going to be $485 for the jod, is the a lot? or its ok, and is it posibell the the on a 2003 jeep that is a city driver the roters will not be good, the guy tolled him the he has to get new roters
1998 XJ Sport 133550M on it as of today.
With a 2 Inch lift and Rancho RS9000X
K&N FIPK
Power Slot Brake Rotors
All New Super Kit Of Bushings From Daystar
Skyjacker TC Lowering Kit, Dynomax kit
arieljeep is offline
post #2 of 9 Old 10-21-2005, 12:01 AM
swyszomirski
how much the rotors wear all depends on the driving style. I live in the mountains in Santa Cruz, Cal. and my brakes are beginning to squeal at 26100 miles, which I think is great mileage for the brakes considering all the hills I drive. The price for the job is probably ok, but then again it depends on where he gets it done, in the more expensive part of town it will be more expensive, etc. I realy haven't priced brakes with a full install because I always do my own, but it is prosible that the rotors can't be turned flat and will need to be replaced.
2004 Liberty (4x4) 5spd. - Rusty's air tube, light bar, front hitch with Mile Marker 8000, air horns, Megawarrior roof basket and fog lights. Sirius
Fighter Jet grip stick for a shifter....
swyszomirski is offline
post #3 of 9 Old 10-22-2005, 07:22 AM
libertygrl
I had the same thing done on my '03 and it cost me about that much...
'03 kj - 4x4 - sport - atlantic blue - wet okole neoprene seats - xtreme front and rear floor mats - jbl speakers - eclipse cd/mp3 player - aftermarket tint
soon to have: 2" lift - american racing baja wheels
libertygrl is offline
post #4 of 9 Old 10-26-2005, 10:57 AM
rwmjeepjk
Does anyone know where to find instructions on how to change the pads/rotors? I am interested in changing my own, I already do most all of the other maintenance, engine work, and upgrades, but have never attempted brakes.
'07 Unlimited X - RED - winch, mod front bumper, 2.5" lift, 35" BFG KM2's, skid row skid plate, BackUp Camera, Custom Switch Pod, CB / PA, Congo Cage customized to full rack with light bar and rear ladder, more to come! (roof tent is not too far off, getting ready for next Easter Jeep Safari trip)
rwmjeepjk is offline
post #5 of 9 Old 10-26-2005, 11:13 AM
swyszomirski
Step:
1- pull off the tire
2- Un-bolt the caliper (where the pads are held in)
3- Pop out brake pads from caliper
4- If you have ABS, then you will need the special caliper pusher that turns the caliper piston as it pushes it back. If no ABS, then a regular caliper pusher will be fine. Make sure in either case to put a block of wood between the end of the pusher and the caliper piston to keep from damaging the piston.
5- I can't remember if there is another piece of metal that holds the caliper to the hub or not, but if there is, remove it.
6- swap rotor
Then reverse process.
All bolts are most likely metric.
post #6 of 9 Old 10-26-2005, 12:39 PM
festerw
festerw's Avatar
He he, where I come from that's called a c-clamp.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #7 of 9 Old 10-26-2005, 08:47 PM
LostRenegade
LostRenegade's Avatar
It's not that hard. I did it myself for the first time about a month ago. I spent about $350 for everything. I picked up slotted cross drilled rotors on E-Bay for about $240, Hawk front pads for $60 and Autozone cheap ones for the rear $20. Plus about another $30 for misc stuff.
LostRenegade - Lost #000477
'03 Liberty Renegade - Mopar Skids, Light Bar,
SilverStars, Boulder Bars, Skid Row Tranny Skid,
K&N Air Filter, Magnaflow Muffler, RUSTY's 2.5" Coil Lift,
BFG AT/KO 245/75R16, KC Hilights Daylighters 150W.
http://www.cardomain.com/id/lostrenegade
LostRenegade is offline
post #8 of 9 Old 10-28-2005, 10:31 AM
rwmjeepjk
Is there any "bleeding" of the brakes involved? I am comfortable in doing all of the other work but get nervous about the thought of that important step.
post #9 of 9 Old 10-28-2005, 11:37 AM
swyszomirski
No, why would you bleed the lines on a typical brake job? You don't totally remove the caliper from the vehicle, you just un-bolt it from the hub = no bleeding, and if you see brake fluid = bad bad
Brake Problems? starbuck461 KJ Liberty Forum 12 10-04-2009 06:13 AM
Brake Pad replacements? psujeeperman02 KJ Liberty Forum 0 03-08-2006 08:25 AM
LED brake light... RipTricket KJ Liberty Forum 3 02-25-2006 10:06 AM
Brake Noise jbsacb KJ Liberty Forum 10 12-04-2005 12:36 PM
Brake Light kellydeen KJ Liberty Forum 1 09-06-2005 05:40 PM
