heater core removal - JeepForum.com
post #1 of 5 Old 11-14-2015, 11:36 AM Thread Starter
jeepliberty0384
heater core removal
Hey was wondering if some one can help me and this is probably asked over and over I have a 2003 jeep liberty 3.7l 4 wheel drive.. I was wondering if someone has step by step instructions with pictures on how to removal the dash and heater core... also is there a way to not mess around with the ac discharge etc ? ANy way around it ??? any help will greatly be appreciated ..
jeepliberty0384 is offline
post #2 of 5 Old 11-14-2015, 02:19 PM
streetglideok
2005 KJ Liberty
No way to avoid discharging the a/c. You have to disconnect the lines to remove the box and replace the heater core.
streetglideok is offline
post #3 of 5 Old 02-17-2017, 11:53 AM
easthou_
2004 KJ Liberty
Heater Core Replacement
Did you resolve this issue? I just replaced the heater core on mine. I have a link to the service manual if you need it.
easthou_ is offline
post #4 of 5 Old 02-18-2017, 08:42 AM
olliehopnoodle
1982 FSJ Cherokee
How bad was it? I have done other work to the liberty (pulled the heads, pulled the engine, brakes, etc) so I have some skill.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #5 of 5 Old 02-20-2017, 10:17 AM
easthou_
2004 KJ Liberty
If you done the work aforementioned, your golden. I've done the same work before and honestly is equally tedious but not as bad as people make it out to be. The whole process took me about a solid week, after work mostly during the weekdays with a headlamp and wrapped everything up on Saturday morning. The heater core is pulled out vertically so you do need to discharge the A/C to remove the HVAC housing to clear the two inlets that penetrate the firewall into the engine bay. To my surprise the inlets are about 1.5" proud past the thermal wall. Hope everything goes well.
easthou_ is offline
