Heater/AC Blower only works on High - JeepForum.com
post #1 of 7 Old 12-14-2008, 11:33 AM Thread Starter
Sevenfootman
The blower in my wifes 06 liberty only works on 4 (or high). The other day when I drove it, it worked on 3 but nothing below that. Now only 4. Checked all the fuses. Any other ideas on what to check and why it works on one setting...but not the other?
Thanks,
SFM
Sevenfootman is offline
post #2 of 7 Old 12-14-2008, 11:52 AM
Jakked
resistor pack needs to be replaced. do a search on this forum, you'll find several threads with instructions on how to DIY if you want to.
2004 Liberty Sport 3.7L A/T 4x4 Cmd-Trc
Former 4x4s:
1999 TJ 4.0L I-6 4x4 5-Sp *Mods*
1986 Trooper 2.3L I-4 4x4 5-sp
Jakked is offline
post #3 of 7 Old 12-15-2008, 11:40 AM
ashtona
My '06 is doing the same thing and sure enough, there is a recall on that very problem. Apparently it "could" cause a fire but in most cases, just burns out like what happened to me, and apparently you.
I would call the dealer before dropping any money into it, no matter how cheap it is to fix.
ashtona is offline
post #4 of 7 Old 12-15-2008, 02:25 PM
jeepjeepster
^Two different things.
There is NOT a recall on the resistor packs. Its a very cheap and easy fix.
jeepjeepster is offline
post #5 of 7 Old 12-15-2008, 02:29 PM
jp7794
2006 KJ Liberty
I lost speed 1 and that is what they replaced. It is still under warranty.
jp7794 is offline
post #6 of 7 Old 12-19-2008, 10:08 AM
stormcr0w
My extended warranty has a $100 deductible so I found a guy who has the genuine mopar parts on fleabay for about $25 shipped, cause the nearest dealer to me is about 45 minutes away. It took me longer to find my 5/16 socket than it did to replace the dang thing. Works like a charm now.
stormcr0w is offline
post #7 of 7 Old 12-20-2008, 05:58 AM
skates04
skates04's Avatar
Easy fix, get it on-line for half of what the local dealers usaully want. I had to replace one on my old TJ and Sure enough the day after I got my Liberty I had to change it as well.....
Lucas
skates04 is offline
2002 Liberty blower works but will not produce hot air kdjf4 KJ Liberty Forum 2 12-03-2008 03:48 PM
Blower Motor Only Works On 4 HARDEIGHT KJ Liberty Forum 10 01-09-2008 05:31 PM
Fan / Blower switch only works on high skates04 KJ Liberty Forum 3 10-03-2007 08:04 PM
Heater Blower Fan Noise JCL_05_CRD KJ Liberty Forum 2 12-21-2005 04:40 PM
Heater/blower issue Blue_Liberty KJ Liberty Forum 5 11-29-2005 04:37 PM
