Heat - JeepForum.com
post #1 of 8 Old 11-23-2013, 06:54 AM Thread Starter
Bain98xj
Heat
Driving to work heat was working fine heard a snap then boom no heat. Anything to look for?
Bain98xj is offline
post #2 of 8 Old 11-23-2013, 06:59 AM
streetglideok
2005 KJ Liberty
First thing, pop the hood, and verify the drive belt is in place and running all the pulleys. Next, verify your coolant level, and that it is full. Where abouts did the noise seem to come from?
streetglideok is offline
post #3 of 8 Old 11-23-2013, 07:06 AM Thread Starter
Bain98xj
Belt is good coolant is full. noise seemed to come from right side of dash
Bain98xj is offline
post #4 of 8 Old 11-23-2013, 07:27 AM Thread Starter
Bain98xj
Also the blower motor is working on all speeds
Bain98xj is offline
post #5 of 8 Old 11-23-2013, 03:35 PM
streetglideok
2005 KJ Liberty
Does the mode selection work, going from defrost vents, to dash vents, to floor?
post #6 of 8 Old 11-23-2013, 03:37 PM Thread Starter
Bain98xj
Yes the mode works if I keep moving the temp back and forth I can get heat but then it goes back cold.
Bain98xj is offline
post #7 of 8 Old 11-23-2013, 05:28 PM
streetglideok
2005 KJ Liberty
Hmm, sounds like a problem with the blend door, or the blend door actuator. I can't tell you right off hand where it is, but it would be behind the dash, possibly viewable from under the dash. Would need to turn the temp control cold to hot, and back to cold while watching it, see what is happening.
post #8 of 8 Old 11-23-2013, 05:48 PM Thread Starter
Bain98xj
Thanks. Ill have to take a look and see what I can find. My understanding was that the temp door is on top of the hvac case. I can see it and feel it moving but I don't have full visibility. Appears that you have to drop the case to get it out if anyone has a different way to access or more info would be awesome
Bain98xj is offline
