Headlights Flickering - JeepForum.com
post #1 of 3 Old 01-27-2016, 06:15 PM Thread Starter
TheSJeske
Anybody else having issues with headlights flickering on and off randomly?
Sounds like it making a clicking sound and can happen when I use the turn signal or power windows.
TheSJeske is offline
post #2 of 3 Old 01-29-2016, 12:02 PM
sonocativo
2002 KJ Liberty
Had that issue with my Ram 1500, it was the multy switch. Replaced and it was ok.
sonocativo is offline
post #3 of 3 Old 01-29-2016, 10:53 PM
Billwill
2002 KJ Liberty
First thing is to check the battery, the battery connections are clean and tight, the negative lead lead going to chassis is tight and the grounding strap grounding the engine to chassis is clean and tight both ends.
The clicking noise you hear is probably the High beam/Low beam relays on either side of the internal fuse box.
Could be the multi function switch as stated also.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
