Headlight problem - random shut off - JeepForum.com
post #1 of 10 Old 02-08-2012, 01:34 PM Thread Starter
Railroadman
2004 KJ Liberty
04 Liberty, regular headlights (not aftermarket etc). On 2 occasions, after driving about a half hour the headlights go out, come on after about 2 seconds, and that repeats maybe 5 times. After that it was fine, drove another half hour no problem. Once was before a new battery, the second time after. The road was smooth, it was not a case of a bump rattling a loose wire. I went over rough bumps at other times with no trace of the problem. Both times it happened, the dash lights stayed on and there was no loss of engine power. Could not tell if tail lights went off or not. I can hear a relay clicking each time they come off or on from behind the dash, left side. I can't make this happen by wiggling the signal lever, pounding on the dash, etc. In fact, I can't make it happen no matter what I do so no smoking gun to trace.
It seems like it could be some sort of circuit breaker resetting, but if something was overheated I would expect it would continue to cycle the rest of the ride, not stop doing it after maybe 30 seconds of off and on.
Any suggestions? Thanks!
Railroadman is offline
post #2 of 10 Old 02-08-2012, 11:42 PM
Billwill
2002 KJ Liberty
There is no circuit breaker involved, only fuses.
As stated above, try repluging the High Beam Relay which is on the interior fuse block. On the rear side of the fuse block are more relays such as the Low Beam Relay, Fog Relay etc. You could try swapping the High Beam Relay with one of these other relays to see if the problem moves.
Billwill is offline
post #3 of 10 Old 02-09-2012, 06:07 AM Thread Starter
Railroadman
2004 KJ Liberty
Thank you! I'll give that a try.
post #4 of 10 Old 10-26-2012, 05:01 AM
jeepjeepster
I know this is an old thread but did you ever figure anything out? Mines recently started doing the exact same thing.
jeepjeepster is offline
post #5 of 10 Old 10-27-2012, 04:43 AM
Billwill
2002 KJ Liberty
Could be the multi-function switch, a loose fuse or a bad relay.
I would re-plug the relevant fuses for that circuit and re-plug/swap the relays mentioned on both sides of the internal fuse panel.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #6 of 10 Old 10-28-2012, 08:50 AM Thread Starter
Railroadman
2004 KJ Liberty
To be honest, we have not gone after the problem YET. I know...it's been a long time. For short night time trips it has not been a problem, and for longer ones after dark we've used another vehicle. Which really accomplishes nothing as far as the problem itself.
I guess this will serve as my wake-up call, and maybe this week I'll try a few things. One problem is the issue is SO intermittent I may THINK I have it fixed and it may be a month before it does it again.
Thanks for the advice, I'll post what I do and how it works.
post #7 of 10 Old 08-31-2013, 01:05 PM
bvanhorn52
2004 KJ Liberty
Head light relays
Doesn't someone know how to find the other Liberty headlight relay that is hidden? I can't find on any of the posts where this is answered.
bvanhorn52 is offline
post #8 of 10 Old 09-02-2013, 02:51 AM
Billwill
2002 KJ Liberty
Here it is..picture shows the rear of the fuse panel inside the cabin...this is for 2002 CRD...should be close enough for newer models.
Billwill is offline
post #9 of 10 Old 09-03-2013, 12:09 PM
USPLiberty
I had to replace my multifunction switch in my Jeep under warrantee. I think that it is the whole turn signal/wiper apparatus. I started to get all kinds of electrical bugaboos. Dash lights blinking for no reason, problems with the lights etc. They are a well known problem even with the Grand Cherokees.
USPLiberty is offline
post #10 of 10 Old 09-03-2013, 12:34 PM
jbarthol
2005 KJ Liberty
The hidden relay's are behind the panel that sits below the steering wheel. Mine is hinged at the bottom, and locked in place at the top via 2 snap fasteners. A panel removal tool may be necessary if you don't have callused hands like mine to pop them out. After that it should be easy to get to.
jbarthol is offline
Headlights shut off Bruce67 KJ Liberty Forum 4 05-30-2010 01:11 AM
headlight problem, no low beams orangez KJ Liberty Forum 12 11-15-2007 12:20 AM
Buzzing when when shut off woodchipper KJ Liberty Forum 26 06-04-2006 08:59 PM
liberty headlight problem sunny1976 KJ Liberty Forum 2 10-18-2004 02:02 PM
Random problem Lady Liberty KJ Liberty Forum 4 07-23-2004 11:55 AM
