hard shifting 2002 - JeepForum.com
post #1 of 5 Old 12-28-2011, 02:20 PM Thread Starter
vwbuge
hard shifting 2002
A friend of mine asked me about her Liberty the other day. She said it was shifting at the right time but the shifts have become harsh. I asked if there was a check engine light on and she said no.
Fast forward to today and she said it is still shifting hard and the check engine light is now on. I have an OBD II scanner and will scan it tomorrow.
Any ideas without seeing a code first? I will post back as soon as I scan it.
vwbuge is offline
post #2 of 5 Old 12-28-2011, 05:18 PM
Powerslave
2006 KJ Liberty
We await your code(s). Can be a multitude of things...
Powerslave is offline
post #3 of 5 Old 12-29-2011, 02:02 PM Thread Starter
vwbuge
P 0734
Gear 4 ratio incorrect.
vwbuge is offline
post #4 of 5 Old 12-30-2011, 01:20 PM
02blue
2002 KJ Liberty
Check the fluid level and quality first.
Check this out:
http://engine-codes.com/p0734_jeep.html
02blue is offline
post #5 of 5 Old 12-30-2011, 06:45 PM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Originally Posted by vwbuge View Post
P 0734
Since your girlfriend's Jeep is an '02 with the 45RFE this info may be incorrect, but with the 4th gear ratio code it's showing a problem with that clutch pack. I believe with that tranny the 2nd and 4th gears share the same clutch pack so your girlfriend is probably noticing the harsh shift from 1st to 2nd and you're getting a code for the 4th gear ratio - but it's all the same problem.
If your scanner can get the CVI numbers while you drive the Jeep. There is a specific range each clutch pack has to be within; if they're out of range then I hate to say it but you're probably looking at a rebuild or replace.
Bob
TwoBobsKJ is offline
03 Libby tranny shifting hard after filter /fluid change gschwoyer KJ Liberty Forum 11 03-26-2014 09:14 AM
liberty shifting hard after taking out of 4wd vhmannp KJ Liberty Forum 0 01-19-2011 06:58 PM
Hard shifting into 3rd gear!!! TeeJay00 KJ Liberty Forum 7 08-19-2010 08:57 PM
How Hot Should A 2002 JK get? BoosLibby KJ Liberty Forum 5 06-15-2010 10:36 PM
Hard shifting on 3.7 auto 1st to 2nd sthsquid KJ Liberty Forum 7 09-30-2005 05:40 PM
