Had the lower ball joints repaired should they do an alignment?
#1 | |
I thought that they would do an alignment for free after the new ball joint install?
#2 |
Take a look at it. Nothing has changed.
2006 Jeep Liberty Sport CRD |
#3 | |
NO it does not need re-alignment and most of the trucks like dakoda, ram, liberty, grand cherokee need only rear alignment no front. |
#4 |
I asked the same thing.
Dealer recommended it but not on recall, thus not done. They said that due to the style, cone in cone hole, new ball joint should not be far off compared to the previous ones. Thus we get screwed again. ![]()
Shawn Kleinsmith Igo, CA (Near Redding) 2004 Liberty (3.6 v6 gas) - Rocky Mountain Edit - Silver/charcoal |
#5 | |
There is no need for an alignment because of ball joint replacement. skleinsmith: how do you figure your getting screwed? I have done an alignment before replacing the ball joints and after as a comparison, there is NO change in camber or castor(I used my wifes as a test) or even toe for that matter. |
#6 | |
Design ignorance, which I am guilty of, or used to be.
#7 | |
we have a solid rear axle, no alignments possible.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
